msi megabook m610 ms-1004 rev 0a
The MSI MS-1004 Rev 0.A motherboard, dated March 10, 2004, is built around the AMD XP-M uPGA563 CPU platform with a SIS M741 North Bridge and SIS 963L South Bridge. It features two DDR SODIMM slots for memory expansion. The system utilizes an LPC BIOS for firmware storage and is managed by a W83950D EC/KBC controller. Power management is handled by a combination of MAX1632, MAX1939, MAX1844, and SC1486 power ICs. Integrated audio is provided by an ALC655 codec, while networking is supported by an RTL8201 LAN PHY. The motherboard includes a Mini PCI slot for wireless connectivity and an ENE 1410 card reader controller. Graphics output is managed by an MST9131 scaler, with a PCM1742 serving as both the DDR clock buffer and audio amplifier. The system is powered by a clock generator from ICS.
A: The motherboard uses a W83950D EC/KBC controller.
Q: What is the CPU socket type for this motherboard?
A: The CPU socket is uPGA563, supporting AMD XP-M processors.
Q: What is the memory architecture and quantity?
A: The motherboard supports DDR memory in two SODIMM slots.
Q: What power management ICs are used?
A: The power management ICs include MAX1632, MAX1939, MAX1844, and SC1486.
Q: What is the audio codec and LAN PHY used?
A: The audio codec is ALC655, and the LAN PHY is RTL8201.
| Brand | MSI |
| Model | MS-1004 |
| Motherboard Manufacturer | MSI CORPORATION |
| Board Number | MS-1004 |
| Revision | 0.A |
| Date | Wednesday, March 10, 2004 |
| CPU Platform | AMD XP-M uPGA563 |
| CPU Socket | uPGA563 |
| North Bridge | SIS M741 |
| South Bridge | SIS 963L |
| EC / KBC | W83950D |
| Audio Codec | ALC655 |
| BIOS / SPI Flash | LPC BIOS |
| Charging IC | MAX1632 |
| Power IC(s) | MAX1939, MAX1844, SC1486 |
| LAN IC | RTL8201 |
| WiFi / WLAN IC | Mini PCI |
| Card Reader IC | ENE 1410 |
| USB Hub IC | USB 2.0 x4 |
| GPU Type | MST9131 |
| Graphics Architecture | Scaler |
| DDR Clock Buffer | PCM1742 |
| Audio Amplifier | PCM1742 |
| Clock Generator | ICS |
| Document Number | Custom |
MS-1004
Xp-m
M741
Northbridge / MCH
963L
W83950D
ALC655
MAX1632
MAX1844
MAX1939
SC1486
DDR
RTL8201
1410
MST9131
Scaler
PCM1742
Audio Amplifier
MS-1004
Xp-m
M741
Northbridge / MCH
963L
W83950D
ALC655
MAX1632
MAX1844
MAX1939
SC1486
DDR
RTL8201
1410
MST9131
Scaler
PCM1742
Audio Amplifier
