msi megabook s260 ms-1012 rev 1.1
The MSI MS-10121 revision 1.1 motherboard, dated January 21, 2005, is built around the Intel Socket 479 platform supporting Dothan and Yonah processors. The platform architecture pairs an Intel 915GM northbridge with an ICH6-M southbridge. System memory consists of DDR DRAM arranged in Channel A configuration. The embedded controller is a W83950DF K/B controller. The system BIOS is stored on a Firmware Hub (FWH) ROM. Power management is handled by a MAX8550 charging IC alongside SC1403, SC1485, and SC451 power ICs. Networking is provided by a Realtek RTL8101 PCI LAN controller. A Ricoh R5C593 controller manages Card Bus, Flash, and IEEE 1394 connectivity. Clock generation is handled by an ICS 954206AG clock generator. Thermal management includes an MS1012-ALVISO Smart Fan sensor.
A: The board number is MS-10121, revision 1.1.
A: The EC/KBC controller is a W83950DF.
A: The charging IC is a MAX8550.
A: The LAN controller is a Realtek RTL8101.
| Brand | MSI (Micro-Star International) |
| Model | MS-10121 |
| Motherboard Manufacturer | MICRO-STAR INT'L CO.,LTD. |
| Board Number | MS-10121 |
| Revision | 1.1 |
| Date | Friday, January 21, 2005 |
| CPU Platform | Intel Socket 479 Dothan/Yonah |
| PCH / Southbridge | ICH6-M |
| Northbridge | Intel 915GM |
| EC / KBC | W83950DF |
| Audio Codec | ALC655 (inferred from AC97 CODEC block, but exact model not explicitly listed) |
| BIOS / SPI Flash | FWH BIOS ROM |
| Charging IC | MAX8550 |
| Power IC(s) | SC1403, SC1485, SC451 |
| RAM Type | DDR DRAM |
| RAM Architecture | Channel A |
| LAN IC | RTL8101 |
| Card Reader IC | R5C593 |
| Clock Generator | ICS 954206AG |
| Thermal Sensor | MS1012-ALVISO (Smart Fan) |
MS-10121
Dothan
Yonah
ICH6
915GM
Northbridge / MCH
W83950DF
ALC655
MAX8550
SC1403
SC1485
SC451
DDR DRAM
RTL8101
R5C593
ICS954206AG
MS1012-ALVISO
MS-10121
Dothan
Yonah
ICH6
915GM
Northbridge / MCH
W83950DF
ALC655
MAX8550
SC1403
SC1485
SC451
DDR DRAM
RTL8101
R5C593
ICS954206AG
MS1012-ALVISO
