Schematic msi megabook m610 ms-1004 rev 0a schematic
BrandMSI
ModelMS-1004
Motherboard ManufacturerMSI CORPORATION
Board NumberMS-1004
Revision0.A
DateWednesday, March 10, 2004
CPU PlatformAMD XP-M uPGA563
CPU SocketuPGA563
North BridgeSIS M741
South BridgeSIS 963L
EC / KBCW83950D
Audio CodecALC655
BIOS / SPI FlashLPC BIOS
Charging ICMAX1632
Power IC(s)MAX1939, MAX1844, SC1486
RAM TypeDDR
RAM ArchitectureSODIMM
RAM Quantity / Slots2
LAN ICRTL8201
WiFi / WLAN ICMini PCI
Card Reader ICENE 1410
USB Hub ICUSB 2.0 x4
GPU TypeMST9131
Graphics ArchitectureScaler
DDR Clock BufferPCM1742
Audio AmplifierPCM1742
Clock GeneratorICS
Document NumberCustom
The MSI MS-1004 Rev 0.A motherboard, dated March 10, 2004, is built around the AMD XP-M uPGA563 CPU platform with a SIS M741 North Bridge and SIS 963L South Bridge. It features two DDR SODIMM slots for memory expansion. The system utilizes an LPC BIOS for firmware storage and is managed by a W83950D EC/KBC controller. Power management is handled by a combination of MAX1632, MAX1939, MAX1844, and SC1486 power ICs. Integrated audio is provided by an ALC655 codec, while networking is supported by an RTL8201 LAN PHY. The motherboard includes a Mini PCI slot for wireless connectivity and an ENE 1410 card reader controller. Graphics output is managed by an MST9131 scaler, with a PCM1742 serving as both the DDR clock buffer and audio amplifier. The system is powered by a clock generator from ICS.
A: The motherboard uses a W83950D EC/KBC controller.
Q: What is the CPU socket type for this motherboard?
A: The CPU socket is uPGA563, supporting AMD XP-M processors.
Q: What is the memory architecture and quantity?
A: The motherboard supports DDR memory in two SODIMM slots.
Q: What power management ICs are used?
A: The power management ICs include MAX1632, MAX1939, MAX1844, and SC1486.
Q: What is the audio codec and LAN PHY used?
A: The audio codec is ALC655, and the LAN PHY is RTL8201.
  • MSI megabook M610=MS-1004 Rev 0A.pdf
