lenovo vawga la-9911p rev-1.0 kabini 0401 premp final 1
This Compal LA-9911P REV: 1.0 motherboard is built on the AMD "Kabini" Platform, featuring an AMD FT3 APU with Jaguar Core and integrated Yangtze FCH. The graphics subsystem is driven by an AMD Sun Pro M2 GPU under the ATI SunVAWGA/B architecture. System memory is configured as single-channel DDRIII 1600MHz across two 204-pin DDRIII SO-DIMM slots. The embedded controller is an ENE KBC9012, and audio is handled by a Conexant CX20757 codec. Wired networking is provided by an Atheros AR8162/8172 LAN IC, with wireless connectivity via a WLANBT Combo module. The system BIOS is stored on a 4M SPI flash device. The board also integrates a card reader and a thermal sensor for system monitoring.
A: The board number is LA-9911P, revision REV: 1.0.
A: The embedded controller is an ENE KBC9012.
A: The BIOS is a 4M (4 megabit) SPI flash device.
Q: What is the memory architecture and configuration?
A: The memory architecture is single-channel DDRIII 1600MHz, using two 204-pin DDRIII SO-DIMM slots.
| Model | VAWGA/B |
| Board Number | LA-9911P |
| Revision | REV: 1.0 |
| Date | 2013-04-01 |
| CPU Platform | AMD "Kabini" Platform |
| CPU Model | AMD FT3 APU BGA 769-balls Jaguar Core |
| PCH / Southbridge | Integrated Yangtze FCH |
| GPU Type | AMD Sun Pro M2 |
| Graphics Architecture | ATI SunVAWGA/B |
| EC / KBC | ENE KBC9012 |
| Audio Codec | Conexant CX20757 |
| BIOS / SPI Flash | BIOS (4M) |
| RAM Type | DDRIII 1600MHz |
| RAM Quantity / Slots | 204pin DDRIII-SO-DIMM X2 |
| LAN IC | Atheros AR8162/8172 |
| WiFi / WLAN IC | WLANBT Combo |
| Card Reader IC | CardReader |
| Thermal Sensor | Thermal Sensor |
