Schematic lenovo vawga la-9911p rev 1.0 kabini 0401 premp final schematic schematic
lenovo vawga la-9911p rev 1.0 kabini 0401 premp final schematic 1
BrandCompal
ModelVAWGA/B
Board NumberLA-9911P
Revision1.0
Date2013-04-01
CPU PlatformAMD "Kabini" Platform
CPU ModelAMD FT3 APU BGA 769-balls Jaguar Core
PCH / SouthbridgeIntegrated Yangtze FCH
GPU TypeATI Sun Pro M2
Graphics ArchitectureVRAM 1GB/2GB DDR3 x4
EC / KBCENE KBC9012
Audio CodecConexant CX20757
BIOS / SPI FlashBIOS (4M)
RAM TypeDDRIII-SO-DIMM X2
RAM ArchitectureSingle Channel BANK 0, 1, 2 204pin 1.5V DDRIII 1600MHz
LAN ICAtheros AR8162/8172
WiFi / WLAN ICMINI Card (WLAN/BT)
This Compal LA-9911P Rev 1.0 motherboard, dated 2013-04-01, is built on the AMD "Kabini" Platform featuring an AMD FT3 APU with Jaguar Core and an Integrated Yangtze FCH. The graphics subsystem is driven by an ATI Sun Pro M2 GPU with 1GB or 2GB of DDR3 VRAM. System memory is provided via two 204-pin DDRIII-SO-DIMM slots operating in single-channel mode at 1.5V and 1600MHz. The embedded controller is an ENE KBC9012, and audio is handled by a Conexant CX20757 codec. The board utilizes a 4MB BIOS SPI flash for firmware storage. Networking is supported by an Atheros AR8162/8172 LAN IC and a MINI Card slot for WLAN/BT combo modules.
A: The board number is LA-9911P, revision 1.0.
A: The embedded controller is an ENE KBC9012.
A: The BIOS SPI flash is 4MB.
A: The motherboard supports two 204-pin DDRIII-SO-DIMM modules in single-channel configuration, running at 1.5V and 1600MHz.
  • Lenovo=1=vawga la-9911p Rev 1.0 kabini_0401 PREMP final_Schematic.zip
