lenovo quanta gc6a ld-note uma diamond-3 intel calpella 1
This Quanta LD-Note Calpella UMA motherboard is based on the Intel Calpella platform with UMA graphics, featuring an Arrandale processor in an rPGA 989 socket paired with the Ibex Peak-M Intel 5 Series Express Chipset. The system uses dual-channel DDR3 SODIMM memory running at 800/1067 MHz with 1.5V. The embedded controller is an ITE8502 in a QFN32 package. BIOS storage is provided by both 2Mbyte and 4Mbyte SPI flash devices. Power management is handled by multiple ICs including the ISL6237IRZ-T, ISL62882, TPS51116REGR, MAX17028, and RT8204, with battery charging controlled by the ISL88731. The audio codec is an ALC269Q, networking is provided by the RTL8111DL LAN controller, and HDMI connectivity uses the PS8101 level shifter. The clock generator is an SLG8SP585V, and the card reader controller is a G990P11U.
A: The embedded controller is an ITE8502 in a QFN32 package.
Q: What BIOS flash configurations are present?
A: The board uses both a 2Mbyte SPI flash and a 4Mbyte SPI flash.
A: The battery charger IC is an ISL88731.
A: The board supports dual-channel DDR3 800/1067 MHz 1.5V memory via two SODIMM slots.
Q: What power management ICs are used?
A: Power regulation ICs include the ISL6237IRZ-T, ISL62882, TPS51116REGR, MAX17028, and RT8204.
| Project Code | LD-Note Calpella UMA |
| Date | Tuesday, November 17, 2009 |
| CPU Platform | Intel Calpella Platform with UMA GFX |
| CPU Model | Arrandale |
| CPU Socket | rPGA 989 |
| PCH / Southbridge | Ibex Peak-M Intel(R) 5 Series Express Chipset |
| GPU Type | UMA |
| Graphics Architecture | UMA |
| EC / KBC | ITE8502 |
| EC/KBC Package | QFN32 |
| Audio Codec | ALC269Q |
| BIOS / SPI Flash | FLASH 2Mbytes, FLASH 4Mbytes |
| Charging IC | ISL88731 |
| Power IC(s) | ISL6237IRZ-T, ISL62882, TPS51116REGR, MAX17028, RT8204 |
| RAM Type | DDR3 |
| RAM Architecture | Dual Channel DDR3 800/1067 1.5V |
| RAM Quantity / Slots | DDR3 - SODIMM0, DDR3 - SODIMM1 |
| Card Reader IC | G990P11U |
| LAN IC | RTL8111DL |
| WiFi / WLAN IC | MINI-CARD WLAN/WiMAX |
| HDMI Level Shifter | PS8101 |
| Clock Generator | SLG8SP585V |
Calpella
Arrandale
989
UMA
IT8502
ALC269Q
ISL88731
ISL6237IRZ-T
ISL62882
MAX17028
RT8204
TPS51116REGR
G990P11U
RTL8111DL
PS8101
SLG8SP585V
Calpella
Arrandale
989
UMA
IT8502
ALC269Q
ISL88731
ISL6237IRZ-T
ISL62882
MAX17028
RT8204
TPS51116REGR
G990P11U
RTL8111DL
PS8101
SLG8SP585V
