Schematic lenovo m30-70 s410 la-a321p zius6 zius7 schematic
lenovo m30-70 s410 la-a321p zius6 zius7 schematic 1
BrandCompal
ModelZIUS6/S7
Motherboard ManufacturerCompal Electronics, Inc.
Project CodeZIUS6/S7
Board NumberLA-A321PR01
Revision0.2
Date2013-03-14
CPU PlatformIntel Haswell ULT
GPU TypeAMD SUN Pro
Graphics ArchitectureAMD SUN Pro
EC / KBCENE KB9012 A4
Audio CodecRealtek ALC233
BIOS / SPI FlashSYS BIOS ROM 8M
BIOS Flash Exact ModelWINBOND W25Q64FVSSIQ
BIOS Flash ManufacturerWINBOND
BIOS Flash Capacity8M
RAM TypeDDR3L 1333/1600
RAM Architecture204pin DDR3L-SO-DIMM X1
RAM Quantity / Slots1
Thermal SensorEMC1403-2-AIZL-TR
Card Reader ICGENESYS GL834L
LAN ICRealtek RTL8111GUS / RTL8106EUS
WiFi / WLAN ICWLAN+BT(Mini Card)
This Compal LA-A321PR01 Rev 0.2 motherboard, designed for the ZIUS6/S7 project, is built around an Intel Haswell ULT processor paired with an AMD SUN Pro discrete GPU. The system BIOS is stored on an 8M WINBOND W25Q64FVSSIQ SPI flash. Embedded controller functions are handled by an ENE KB9012 A4. Memory configuration consists of a single 204-pin DDR3L SO-DIMM slot supporting 1333/1600 MHz. The audio subsystem uses a Realtek ALC233 codec, and networking is provided by a Realtek RTL8111GUS or RTL8106EUS LAN IC. A GENESYS GL834L IC manages the card reader, and thermal monitoring is performed by an EMC1403-2-AIZL-TR sensor.
Q: What is the exact BIOS flash IC model used on this motherboard?
A: The BIOS flash IC is a WINBOND W25Q64FVSSIQ with a capacity of 8M.
A: The embedded controller is an ENE KB9012 A4.
Q: What is the memory configuration for this motherboard?
A: The motherboard supports a single 204-pin DDR3L SO-DIMM module at 1333/1600 MHz.
Q: What is the discrete GPU on this motherboard?
A: The discrete GPU is an AMD SUN Pro.
  • lenovo m30-70 s410 la-a321p zius6 zius7 r02 0314.pdf
