Schematic toshiba satellite m30-m35-m35x compal la-2462 rev 0.1 schematic
toshiba satellite m30-m35-m35x compal_la-2462_rev 0.1 schematic
toshiba satellite m30-m35-m35x=1=compal_la-2462_rev 0.1.pdf
BrandCompal
ModelEAL20 LA-2462
Project CodeFortworth Banias
Board NumberEAL20 LA-2462
Revision0.1
DateFriday, September 17, 2004
CPU PlatformuFC-PGA Dothan / Montara-GM
PCH / SouthbridgeIntel ICH4-M
GPU TypeATI M11-P
Graphics ArchitectureDiscrete (ATI M11-P) with 32/64/128MB On Board VRAM
dGPU Chip NumberATI M11-P
dGPU to UMA Conversion SupportYes (Fortworth Banias Comparison Table shows UMA option with CH7011A TV Encoder)
EC / KBCSMSC LPC47N217
Audio CodecALC250 Ver.C
BIOS / SPI Flash512KB BIOS
Charging ICNot explicitly listed
RAM TypeDDR200/266/333
RAM Architecture200pin DDR-SO-DIMM X2
RAM Quantity / Slots2
Thermal SensorADI ADM1032AR
Card Reader ICENE CB714/CB1410
LAN ICRTL8100CL
WiFi / WLAN ICMini PCI socket (3.3V 48MHz)
HDMI Level ShifterNot explicitly listed
The Compal EAL20 LA-2462 (Rev 0.1) is a Compal Electronics motherboard designed for the Fortworth Banias project, supporting uFC-PGA Dothan / Montara-GM CPU platforms. It features an Intel ICH4-M southbridge and a discrete ATI M11-P GPU with 32/64/128MB on-board VRAM, with documented UMA conversion support using a CH7011A TV Encoder. The system uses DDR200/266/333 memory via two 200-pin DDR-SO-DIMM slots. The EC/KBC is an SMSC LPC47N217 Super I/O, and the audio codec is an ALC250 Ver.C. The BIOS is a 512KB flash. Networking is handled by a Realtek RTL8100CL LAN IC, with WiFi via a Mini PCI socket. Thermal monitoring uses an ADI ADM1032AR sensor, and the card reader controller is an ENE CB714/CB1410.
A: The EC/KBC is an SMSC LPC47N217 Super I/O.
A: Yes, the Fortworth Banias Comparison Table indicates UMA support using a CH7011A TV Encoder as an alternative to the discrete ATI M11-P GPU.
A: The BIOS is a 512KB flash.
Q: What memory type and configuration does this motherboard support?
A: It supports DDR200/266/333 memory via two 200-pin DDR-SO-DIMM slots.
  • Toshiba Satellite M30-M35-M35X=1=compal_la-2462_Rev 0.1.zip
