ibm x220t dasher-1h0227 schematic 1
The Wistron Dasher-1 (A31101 Rev A3) motherboard is built around the Intel Sandy Bridge CPU platform paired with the Intel Cougar Point PCH. Graphics are handled by the integrated Sandy Bridge GPU core. System memory consists of two unbuffered DDR3 1333MHz SODIMM slots. The embedded controller is a Thinker-1 device. The BIOS is stored on a SPI-FLASH IC. Power management is handled by a TPS51220ARSN system DC/DC converter, a BQ24742 battery charger/selector, and multiple VT1316/VT1317, VT357FCX, VT356FCX, VT355FCX, and TPS62060 voltage regulators. The audio codec is an ALC device. Networking includes an Intel LEWISVILLE WLAN card and a Rinken-2 LAN IC. A USB2514B USB hub and an EMC1428 thermal sensor are also present. The board features a MAX1510 HDMI level shifter and an R4F2113 card reader controller.
A: The board number is A31101, revision A3.
Q: What CPU platform and PCH does this motherboard use?
A: It uses the Intel Sandy Bridge CPU platform with the Intel Cougar Point PCH.
A: It supports two unbuffered DDR3 1333MHz SODIMM modules.
A: The embedded controller is a Thinker-1 device.
A: The charging IC is a BQ24742 battery charger/selector.
| Model | Dasher-1 |
| Project Code | Dasher-1 |
| Board Number | A31101 |
| Revision | A3 |
| Date | Wednesday, January 12, 2011 |
| CPU Platform | Intel Sandy Bridge |
| PCH / Southbridge | Intel Cougar Point |
| GPU Type | Intel Integrated Graphics |
| Graphics Architecture | Intel Sandy Bridge Integrated Graphics |
| EC / KBC | Thinker-1 |
| Audio Codec | ALC |
| BIOS / SPI Flash | SPI-FLASH |
| Charging IC | BQ24742 |
| Charger Architecture | Battery Charger/Selector |
| Power IC(s) | TPS51220ARSN, VT1316/VT1317, VT357FCX, VT356FCX, VT355FCX, TPS62060 |
| RAM Type | DDR3 1333MHz |
| RAM Architecture | Unbuffered DDR3 SODIMM |
| Thermal Sensor | EMC1428 |
| Card Reader IC | R4F2113 |
| USB Hub IC | USB2514B |
| LAN IC | Rinken-2 |
| WiFi / WLAN IC | Intel LEWISVILLE |
| HDMI Level Shifter | MAX1510 |
DASHER-1
A31101
Sandy Bridge
THINKER-1
BQ24742
TPS51220ARSN
TPS62060
VT1316
VT1317
VT355FCX
VT356FCX
VT357FCX
EMC1428
R4F2113
USB2514B
RINKEN-2
MAX1510
DASHER-1
A31101
Sandy Bridge
THINKER-1
BQ24742
TPS51220ARSN
TPS62060
VT1316
VT1317
VT355FCX
VT356FCX
VT357FCX
EMC1428
R4F2113
USB2514B
RINKEN-2
MAX1510
