HP VICTUS 16 Quanta G3MQ N18P MV D8 DAG3MQMBAE0 Rev E Schematic pdf file
Taffyta AMD Cezanne+ NV GN20P/N18P-G61
This Quanta G3MQNB5 motherboard, documented under Custom3A revision 1106 dated April 28, 2021, is built around the AMD Cezanne FP6 APU platform supporting DDR4 3200MHz memory via two SODIMM slots. The discrete graphics subsystem features NVIDIA GN20-P0 and GN20-P1 GPU options, along with the N18P-G61-A variant, each paired with four GDDR6 VRAM chips. System management is handled by an IT5570 EC/KBC, which also integrates fan control. Audio is provided by a Realtek ALC3315-CG codec, while networking is served by a Realtek RTL8118ASH-CG LAN controller. Storage connectivity includes multiple PCIe lanes for SSDs and SATA ports, with a GL9750 card reader. Display output is managed through a PI3HDX12211ZHEX HDMI re-driver and a TUSB544 multi-protocol linear re-driver for USB-C. Power delivery and charging are controlled by a TPS65987DDJ PD controller. Security is supported by an SLB9670VQ2.0 TPM module.
Q: What EC/KBC is used on this Quanta G3MQNB5 motherboard?
A: The motherboard uses an IT5570 EC/KBC, which also integrates fan control functionality.
Q: What are the discrete GPU options for this motherboard?
A: The motherboard supports NVIDIA GN20-P0 (60W +15W), GN20-P1 (60W +15W), and N18P-G61-A (50W) GPU configurations, each with four GDDR6 memory chips.
Q: What audio codec and LAN controller are present?
A: The audio codec is a Realtek ALC3315-CG, and the LAN controller is a Realtek RTL8118ASH-CG.
Q: What memory configuration does this platform support?
A: The platform supports DDR4 3200MHz memory via two SODIMM slots, with a maximum of 16GB per slot.
| Project Code | G3MQNB5 |
| Document Number | Custom3A |
| Revision | 1106 |
| Date | Wednesday, April 28, 2021 |
| CPU Platform | AMD Cezanne (FP6) |
| GPU Type | NVIDIA GN20P/N18P-G61 |
| dGPU Chip Number | GN20-P0, GN20-P1, N18P-G61-A |
| EC / KBC | IT5570 |
| Audio Codec | ALC3315-CG |
| RAM Type | DDR4 3200MHz |
| RAM Architecture | SODIMM |
| LAN IC | RTL8118ASH-CG |
| Card Reader IC | GL9750 |
| USB Hub IC | TUSB544 |
| HDMI Level Shifter | PI3HDX12211ZHEX |
| Charging IC | TPS65987DDJ |
| TPM | SLB9670VQ2.0 |
| FAN Controller | IT5570 |
| RGB Backlight | RGB Backlight |
G3MQNB5
Cezanne
GN20P
N18P-G61
GN20-P0
GN20-P1
N18P-G61-A
IT5570
ALC3315-CG
RTL8118ASH-CG
GL9750
TUSB544
PI3HDX12211ZHEX
TPS65987DDJ
SLB9670VQ2.0
IT5570
G3MQNB5
Cezanne
GN20P
N18P-G61
GN20-P0
GN20-P1
N18P-G61-A
IT5570
ALC3315-CG
RTL8118ASH-CG
GL9750
TUSB544
PI3HDX12211ZHEX
TPS65987DDJ
SLB9670VQ2.0
IT5570
