Schematic hp stream 14-ax series quanta 0p9 da0p9mb16d0 schematic
BrandQuanta
ModelOP9
Motherboard ManufacturerQuanta Computer Inc.
Project CodeOP9
Document Number1A137
Revision1A
DateTuesday, June 07, 2016
CPU PlatformIntel Brasswell
CPU PackageBGA1170
EC / KBCIT8987
Audio CodecALC3227
RAM TypeDDR3L
RAM ArchitectureMemory down, 4 pcs
Card Reader ICRTS5239-GR
WiFi / WLAN ICWLAN
The Quanta OP9 motherboard is built on the Intel Brasswell platform, utilizing a BGA1170 package CPU. The system memory architecture consists of DDR3L memory down with four onboard chips. The embedded controller is an IT8987, and the audio subsystem is managed by a Realtek ALC3227 codec. For storage and expansion, the board supports eMMC 4.5, an NGFF M.2 SSD via SATA, and an NGFF M.2 slot for WLAN. A Realtek RTS5239-GR card reader IC is present for SD card support. The platform integrates USB 3.0 and USB 2.0 ports, an HDMI port, and an eDP panel interface. The block diagram indicates a Fast SPI interface for BIOS/SPI flash, though the exact flash model is not specified in the provided source.
Q: What is the project code and board revision for this Quanta motherboard?
A: The project code is OP9, and the document number is 1A137 with revision 1A.
Q: What EC/KBC controller is used on the Quanta OP9?
A: The embedded controller is an IT8987.
A: The audio codec is a Realtek ALC3227.
Q: What type of memory architecture does the Quanta OP9 use?
A: The board uses DDR3L memory down architecture with four onboard memory chips.
  • HP Stream 14-Ax Series=Quanta 0P9 DA0P9MB16D0.pdf
