hp stream 11-d000 da0y0ambc60 1
This Quanta Y0A NB5HW motherboard is built on the Intel Bay Trail-M platform with a choice of N2940 1.83G QGQL or N2840 2.16G QGQG CPU in an FCBGA 1170 package. The system uses DDR3L 1333 memory in a down configuration. Embedded controller functions are handled by an ITE 8987 in a VFBGA128 package. Audio is provided by an ALC3227 codec in a QFN-48 package. The board features a 1.8V BIOS plus TXE SPI ROM of 8MB capacity. Networking is supported by a SELAN S9653D-24H0AJ0 LAN IC. A GL852G-OHG12 USB hub IC and RTS5141-GR card reader controller are present. Thermal management uses a TMP432A sensor. The HDMI interface is translated via an RTD2132N DP to LVDS translator. A SLB9665TT2.0 TPM module with firmware 5.00 is also integrated.
A: The embedded controller is an ITE 8987 in a VFBGA128 package.
A: The board uses a 1.8V BIOS plus TXE SPI ROM with 8MB capacity.
Q: What audio codec is used?
A: The audio codec is an ALC3227 in a QFN-48 package.
Q: What memory type and architecture does this board use?
A: The board uses DDR3L 1333 memory in a down configuration.
| Project Code | Y0A |
| Board Number | NB5HW |
| Revision | 1A |
| Date | Monday, July 21, 2014 |
| CPU Platform | Intel Bay Trail-M |
| CPU Model | N2940 1.83G QGQL (FCBGA) / N2840 2.16G QGQG (FCBGA) |
| CPU Package | FCBGA 1170 |
| EC / KBC | ITE 8987 |
| EC/KBC Package | VFBGA128 |
| Audio Codec | ALC3227 |
| Audio Codec Package | QFN-48 |
| BIOS / SPI Flash | 1.8V BIOS + TXE SPI ROM (8M) |
| RAM Type | DDR3L |
| RAM Architecture | Memory down |
| RAM Speed | 1333 |
| LAN IC | SELAN S9653D-24H0AJ0 |
| Card Reader IC | RTS5141-GR |
| USB Hub IC | GL852G-OHG12 |
| Thermal Sensor | TMP432A |
| TPM | SLB9665TT2.0 FW 5.00 |
| HDMI Level Shifter | RTD2132N |
Y0A
NB5HW
Bay Trail-M
FCBGA 1170
8987
ALC3227
1.8V BIOS + TXE
DDR3L
RTS5141-GR
GL852G-OHG12
TMP432A
RTD2132N
Y0A
NB5HW
Bay Trail-M
FCBGA 1170
8987
ALC3227
1.8V BIOS + TXE
DDR3L
RTS5141-GR
GL852G-OHG12
TMP432A
RTD2132N
