hp stream 13 quanta y0bc day0bcmb6d0 rev 1a (07.29.2015) 1
This Quanta Y0BC 1A115 motherboard is built on the Intel Brasswell platform, featuring a BGA1170 package CPU with a 4.5-watt TDP. The graphics subsystem is UMA (11.6") based on the Intel Brasswell-M architecture. System memory consists of DDR3L memory-down configuration with four ICs running at 1600MT/s. The embedded controller and keyboard controller are handled by an IT8987 IC. Audio is managed by a Realtek ALC 3227 codec. Storage is provided by eMMC 4.51 with capacities of 32G, 64G, or 128G. A Realtek RTS5239-GR card reader IC is present. The charging subsystem is managed by a BQ24780S charger IC. The board also includes a USB 2.0 Hub, an HDMI level shifter, and an eDP to LVDS converter. The board was designed by Quanta Computer Inc. with a revision date of Wednesday, July 29, 2015.
Q: What EC/KBC is used on this Quanta Y0BC 1A115 motherboard?
A: The EC/KBC is an IT8987.
Q: What is the memory configuration on this board?
A: The board uses DDR3L memory-down architecture with four ICs running at 1600MT/s.
A: The audio codec is a Realtek ALC 3227.
Q: What card reader IC is present on this board?
A: The card reader IC is a Realtek RTS5239-GR.
Q: What is the charging IC on this Quanta Y0BC 1A115?
A: The charging IC is a BQ24780S.
| Project Code | Y0BC |
| Board Number | 1A115 |
| Revision | 1 |
| Date | Wednesday, July 29, 2015 |
| CPU Platform | Intel Brasswell |
| CPU Package | BGA1170 |
| CPU Power | 4.5 (Watt) |
| GPU Type | UMA (11.6") |
| Graphics Architecture | Intel Brasswell-M |
| EC / KBC | IT8987 |
| Audio Codec | ALC 3227 |
| RAM Type | DDR3L |
| RAM Architecture | Memory down*4pcs |
| RAM Speed | 1600MT/s |
| Card Reader IC | RTS5239-GR |
| LAN IC | IT8987 |
| WiFi / WLAN IC | BT COMBONGFF M2 |
| Storage | eMMC 4.51 |
| Storage Capacity | 32G/64G/128G |
| Charger IC | BQ24780S |
| Charger Architecture | Charger |
| Power IC(s) | MOIC |
| USB Hub IC | USB 2.0 Hub |
| HDMI Level Shifter | HDMI |
| eDP to LVDS | eDP to LVDS |
| Document Number | 1A115 |
