Schematic hp quanta u93u lean g amd kabini uma rev 1a 0527 schematic
hp quanta_u93u_lean_g_amd_kabini_uma_rev_1a_0527_dr-bios.com hp quanta_u93u_lean_g_amd_kabini_uma_rev_1a_0527_dr-bios.com schematic
hp=quanta u93u lean g amd kabini uma rev 1a 0527.pdf
BrandQuanta Computer Inc.
Project CodeU93U
Document NumberERD1AA3126
DateFriday, June 06, 2014
CPU PlatformAMD KABINI FT3
EC / KBCiTE IT8528E/HX
EC/KBC PackageLQPF128
Audio CodecALC3227-CG
BIOS / SPI FlashSystem BIOS SPI ROM
EC Flash / ROMEC SPI ROM
Charging ICTI BQ24728
Power IC(s)GMT G5934RZU, Ricktek RT8223PZT, TI TPS51216, Intersil ISL6277HRTZ/ISL6208BCRZ, AOZ1237QI/APW8824CTI/G9183, Richtek RT8068A
RAM TypeDDR3
RAM ArchitectureDDR3 SO-DIMM
RAM Quantity / Slots2
Card Reader ICRealtek RTS5239-GRT
LAN ICRealtek RTL8166EH-CG
WiFi / WLAN ICIntel Rambo Peak
The Quanta U93U project is an AMD KABINI FT3 platform motherboard documented under ERD1AA3126, dated June 6, 2014. The system utilizes an AMD APU in a 769-pin FT3 BGA package and supports up to 8GB per channel of DDR3 SO-DIMM memory across two slots. The embedded controller is an iTE IT8528E/HX in an LQFP128 package, with a dedicated EC SPI ROM for firmware storage. The system BIOS is stored on a separate SPI ROM. Power management is handled by a multi-rail architecture including a TI BQ24728 charging IC, Intersil ISL6277HRTZ/ISL6208BCRZ for processor power, and additional regulators from GMT, Ricktek, TI, AOZ/APW, and Richtek. The board integrates a Realtek RTL8166EH-CG LAN controller, an ALC3227-CG audio codec, a Realtek RTS5239-GRT card reader, and an Intel Rambo Peak WLAN/BT combo module.
Q: What EC/KBC is used on this Quanta U93U motherboard?
A: The embedded controller is an iTE IT8528E/HX in an LQFP128 package, with a dedicated EC SPI ROM.
Q: What is the memory architecture of this platform?
A: The board supports DDR3 800-1600 MT/s memory via two DDR3 SO-DIMM slots, with a maximum of 8GB per slot.
A: The system uses a TI BQ24728 charging IC for system charge power management.
Q: What LAN and audio controllers are integrated?
A: The LAN controller is a Realtek RTL8166EH-CG in an OFN48 package, and the audio codec is an ALC3227-CG in an MQFN package.
  • HP=Quanta_U93U_Lean_G_AMD_KABINI_UMA_Rev_1a_0527_DR-BIOS.COM.zip
