hp quanta_u93u_lean_g_amd_kabini_uma_rev_1a_0527_dr-bios.com hp quanta_u93u_lean_g_amd_kabini_uma_rev_1a_0527_dr-bios.com schematic
hp=quanta u93u lean g amd kabini uma rev 1a 0527.pdf
The Quanta U93U project is an AMD KABINI FT3 platform motherboard documented under ERD1AA3126, dated June 6, 2014. The system utilizes an AMD APU in a 769-pin FT3 BGA package and supports up to 8GB per channel of DDR3 SO-DIMM memory across two slots. The embedded controller is an iTE IT8528E/HX in an LQFP128 package, with a dedicated EC SPI ROM for firmware storage. The system BIOS is stored on a separate SPI ROM. Power management is handled by a multi-rail architecture including a TI BQ24728 charging IC, Intersil ISL6277HRTZ/ISL6208BCRZ for processor power, and additional regulators from GMT, Ricktek, TI, AOZ/APW, and Richtek. The board integrates a Realtek RTL8166EH-CG LAN controller, an ALC3227-CG audio codec, a Realtek RTS5239-GRT card reader, and an Intel Rambo Peak WLAN/BT combo module.
Q: What EC/KBC is used on this Quanta U93U motherboard?
A: The embedded controller is an iTE IT8528E/HX in an LQFP128 package, with a dedicated EC SPI ROM.
Q: What is the memory architecture of this platform?
A: The board supports DDR3 800-1600 MT/s memory via two DDR3 SO-DIMM slots, with a maximum of 8GB per slot.
A: The system uses a TI BQ24728 charging IC for system charge power management.
Q: What LAN and audio controllers are integrated?
A: The LAN controller is a Realtek RTL8166EH-CG in an OFN48 package, and the audio codec is an ALC3227-CG in an MQFN package.
| Project Code | U93U |
| Document Number | ERD1AA3126 |
| Date | Friday, June 06, 2014 |
| CPU Platform | AMD KABINI FT3 |
| EC / KBC | iTE IT8528E/HX |
| EC/KBC Package | LQPF128 |
| Audio Codec | ALC3227-CG |
| BIOS / SPI Flash | System BIOS SPI ROM |
| EC Flash / ROM | EC SPI ROM |
| Charging IC | TI BQ24728 |
| Power IC(s) | GMT G5934RZU, Ricktek RT8223PZT, TI TPS51216, Intersil ISL6277HRTZ/ISL6208BCRZ, AOZ1237QI/APW8824CTI/G9183, Richtek RT8068A |
| RAM Architecture | DDR3 SO-DIMM |
| Card Reader IC | Realtek RTS5239-GRT |
| LAN IC | Realtek RTL8166EH-CG |
| WiFi / WLAN IC | Intel Rambo Peak |
U93U
Kabini
IT8528E/HX
ALC3227-CG
BQ24728
AOZ1237QI
APW8824CTI
G9183
GMT G5934RZU
ISL6208BCRZ
ISL6277HRTZ
RICKTEK RT8223PZT
RT8068A
TPS51216
RTS5239-GRT
RTL8166EH-CG
U93U
Kabini
IT8528E/HX
ALC3227-CG
BQ24728
AOZ1237QI
APW8824CTI
G9183
GMT G5934RZU
ISL6208BCRZ
ISL6277HRTZ
RICKTEK RT8223PZT
RT8068A
TPS51216
RTS5239-GRT
RTL8166EH-CG
