Schematic hp pavilion dm1-4175nr quanta nm9 brazos pv 0617 schematic
hp pavilion dm1-4175nr quanta nm9 brazos pv 0617 1
BrandQuanta Computer Inc.
Project CodeButternut(NM9)
DateTuesday, May 24, 2011
CPU PlatformAMD Ontario
PCH / SouthbridgeHUDSON-M1
GPU TypeAMD FT1
EC / KBCIT8518
Audio CodecAZALIA HD AUDIO
BIOS / SPI FlashSPI Flash
Charging ICOZ8681
Charger ArchitectureBATT Charger OZ8681
Power IC(s)RT8228AZ, RT8223, OZ8380, RT8207, G5173
RAM TypeDDR3
RAM ArchitectureSingle Channel
RAM Quantity / Slots2 (SO-DIMM-1, SO-DIMM-2)
LAN ICRTL8111E
WiFi / WLAN ICWLAN
Card Reader ICCard Reader
This Quanta Butternut (NM9) motherboard, dated May 24, 2011, is built around the AMD Ontario CPU platform paired with the HUDSON-M1 Fusion Controller Hub (FCH). Graphics are handled by the integrated AMD FT1 GPU. The system uses an IT8518 embedded controller (EC/KBC) and an AZALIA HD AUDIO codec. The BIOS is stored on a SPI Flash memory IC. Power management is handled by a combination of ICs including the OZ8681 battery charger, OZ8380 CPU core regulator, RT8228AZ, RT8223, RT8207, and G5173 regulators. Memory configuration consists of two DDR3 SO-DIMM slots operating in single-channel mode at 1333MT/s. Networking is provided by a Realtek RTL8111E LAN controller and a separate WLAN module. The board also includes a card reader and an SLG55448VTR for discharge control.
Q: What EC/KBC is used on this Quanta Butternut (NM9) motherboard?
A: The embedded controller is an IT8518.
Q: What is the charging IC and architecture on this board?
A: The battery charger IC is an OZ8681.
Q: What is the CPU platform and PCH on this motherboard?
A: The CPU platform is AMD Ontario, and the PCH/Southbridge is the HUDSON-M1.
Q: What is the memory configuration for this board?
A: The board supports DDR3 memory in a single-channel architecture via two SO-DIMM slots.
  • HP_Pavilion_DM1-4175nr=1=Quanta_NM9_Brazos_PV_0617.pdf
