hp dm1 dm1-4175nr quanta nm9 daonm9mb6do 1
The Quanta Butternut (NM9) motherboard, revision 1A dated May 24, 2011, is built around the AMD Ontario APU platform paired with the HUDSON-M1 Fusion Controller Hub. The system integrates an IT8518 EC/KBC in a 413-pin 19mm x 19mm BGA package. BIOS is stored on an SPI Flash device. Audio is handled by an AZALIA HD AUDIO codec. The charging architecture uses an OZ8681 battery charger. Power regulation is managed by multiple ICs including RT8228AZ, RT8223, OZ8380, RT8207, G5173, and SLG55448VTR. Memory configuration supports up to 4GB per slot via two DDR3 SO-DIMM slots operating in single-channel mode at 1333MT/s. Networking is provided by a Realtek RTL8111E LAN controller and a combined BT/WLAN module. The board also includes a card reader and USB 2.0 hub functionality.
A: The motherboard uses an IT8518 EC/KBC in a 413-pin 19mm x 19mm BGA package.
A: The charging IC is an OZ8681 battery charger.
A: The LAN controller is a Realtek RTL8111E.
Q: What is the memory configuration of this motherboard?
A: The motherboard supports up to 4GB per slot via two DDR3 SO-DIMM slots in single-channel mode at 1333MT/s.
| Brand | Quanta |
| Model | Butternut (NM9) |
| Project Code | Butternut (NM9) |
| Board Number | NM9 |
| Revision | 1A |
| Date | Tuesday, May 24, 2011 |
| CPU Platform | AMD Ontario |
| PCH / Southbridge | HUDSON-M1 |
| GPU Type | AMD Ontario |
| EC / KBC | IT8518 |
| EC/KBC Package | 413pin 18W TDP ~1.5W 19mm x 19mm BGA |
| Audio Codec | AZALIA HD AUDIO |
| Charging IC | OZ8681 |
| Charger Architecture | BATT Charger OZ8681 |
| Power IC(s) | RT8228AZ, RT8223, OZ8380, RT8207, G5173, SLG55448VTR |
| RAM Quantity / Slots | 2 (SO-DIMM-1, SO-DIMM-2) |
| LAN IC | RTL8111E |
| WiFi / WLAN IC | BT / WLAN |
| Card Reader IC | Card Reader |
| USB Hub IC | USB 2.0 |
