hp omnibook xe3 compal la-1012 rev 1.0
This Compal LA-1012 Rev 1.0 motherboard, dated 2001/09/01, is designed for the N32N101 model and supports uFCBGA/uFCPGA Coppermine-T or Tualatin CPUs with the Almador-M chipset. The platform integrates an Almador-M GMCH-M GPU with DVOA and DVOC bus interfaces for graphics output, paired with an ICH3-M southbridge. System memory is provided via two SO-DIMM slots across four banks. The embedded controller is an NS PC87591, complemented by an NS PC87391 Super I/O. Audio is handled by an ICS9250-38 codec, while networking is managed by an 82562ET LAN controller. Power management includes an OZ6933 charging IC and a dedicated DC/DC interface. Thermal monitoring is performed by a MAX1617MEE sensor. The board also features a ROM BIOS, a Mini PCI socket for wireless expansion, a TV-Out encoder, and an OZ163 card reader IC.
A: The board number is LA-1012, revision 1.0.
A: The embedded controller is an NS PC87591.
Q: What is the CPU platform and chipset configuration?
A: The platform supports uFCBGA/uFCPGA Coppermine-T or Tualatin CPUs with the Almador-M chipset, featuring an Almador-M GMCH-M northbridge and an ICH3-M southbridge.
Q: What audio codec and LAN controller are present?
A: The audio codec is an ICS9250-38, and the LAN controller is an 82562ET.
A: The motherboard supports two SO-DIMM modules across four banks (BANK 0, 1, 2, 3).
| Model | N32N101 |
| Board Number | LA-1012 |
| Date | 2001/09/01 |
| CPU Platform | uFCBGA/uFCPGA Coppermine-T or Tualatin CPU with Almador-M chipset |
| EC / KBC | NS PC87591 |
| Super I/O | NS PC87391 |
| Audio Codec | ICS9250-38 |
| BIOS / SPI Flash | ROM BIOS |
| Charging IC | OZ6933 |
| Thermal Sensor | MAX1617MEE |
| LAN IC | 82562ET |
| RAM Type | SO-DIMM X2 |
| PCH / Southbridge | ICH3-M |
| GPU Type | Almador-M GMCH-M |
| Graphics Architecture | DVOA Bus Interface, DVOC Bus Interface |
| Card Reader IC | OZ163 |
| USB Hub IC | USB & BlueTooth IC |
| WiFi / WLAN IC | Mini PCI Socket |
| HDMI Level Shifter | TV-Out Encoder |
| Power IC(s) | DC/DC Interface |
| Charger Architecture | Battery Charger |
| RAM Architecture | BANK 0, 1, 2, 3 |
| Document Number | 4012002ASCHEMATIC, M/B LA-1012 |
LA-1012
Coppermine-t OR Tualatin
NS PC87591
NS PC87391
Super I/O
ICS9250-38
OZ6933
MAX1617MEE
82562ET
ICH3
OZ163
LA-1012
NS PC87591
NS PC87391
Super I/O
ICS9250-38
OZ6933
MAX1617MEE
82562ET
ICH3
OZ163
