hp omnibook xe3 compal la-1012_rev1c schematic
hp omnibook xe3=1=compal la-1012_rev1c.pdf
The Compal LA-1012 Rev 1.0 motherboard, model N32N101, is designed for the uFCBGA/uFCPGA Coppermine-T or Tualatin CPU platform paired with the Almador-M chipset and ICH3-M southbridge. System management is handled by the NS PC87591 embedded controller, with the NS PC87391 providing Super I/O functionality. The board features an ICS9250-38 audio codec and an 82562ET LAN controller. Power management includes an OZ6933 charging IC and an OZ163 card reader controller. Thermal monitoring is managed by a MAX1617MEE sensor. Memory architecture supports SO-DIMM X2 across four banks. Graphics are driven by the Almador-M GMCH-M with AGP 4X support. Additional connectivity includes a VCH IEEE-1394 controller and a CH TV-Out encoder.
Q: What embedded controller is used on the Compal LA-1012?
A: The NS PC87591 is used as the embedded controller.
Q: What is the CPU platform supported by this motherboard?
A: The board supports uFCBGA/uFCPGA Coppermine-T or Tualatin CPUs with the Almador-M chipset.
Q: What audio codec is present on this board?
A: The ICS9250-38 is the audio codec.
Q: What LAN controller is integrated?
A: The 82562ET is the LAN controller.
| Model | N32N101 |
| Board Number | LA-1012 |
| Date | 2001/09/01 |
| CPU Platform | uFCBGA/uFCPGA Coppermine-T or Tualatin CPU with Almador-M chipset |
| PCH / Southbridge | ICH3-M |
| EC / KBC | NS PC87591 |
| Super I/O | NS PC87391 |
| Audio Codec | ICS9250-38 |
| BIOS / SPI Flash | ROM |
| Charging IC | OZ6933 |
| Thermal Sensor | MAX1617MEE |
| LAN IC | 82562ET |
| Card Reader IC | OZ163 |
| RAM Architecture | SO-DIMM X2 |
| RAM Quantity / Slots | BANK 0, 1, 2, 3 |
| GPU Type | Almador-M GMCH-M |
| Graphics Architecture | AGP 4X |
| IEEE-1394 Controller | VCH |
| TV-Out Encoder | CH |
