hp mini 5102 gucci20 6050a2283001-mb rev ax3 pv 2009.10.24
This INVENTEC AX2 motherboard, project code GUCCI 2.0, board number 1310A2230401-0-MTR, revision 1.0, dated 23-Oct-2009, is built around the Intel Pineview CPU platform with an Intel Tigerpoint PCH/southbridge. Graphics are integrated. The system uses dual DDR2 SODIMM channels for memory. The EC/KBC is an SMSC 1098, and the audio codec is an ICS_92HD75B. The BIOS SPI flash is an SST25VF016B. Power management is handled by a TI_BQ24740_QFN_28PU system charger IC, with additional power ICs including TI_TPS51610, APL5930, TPS51125, TPS51117, and TPS51100. Networking is provided by a MARVEL 88E8072 LAN controller. The motherboard also features an STMicro LIS302DL accelerometer and an ICS9LRS3165/CK505M clock generator.
Q: What BIOS flash IC is used on this motherboard?
A: The BIOS SPI flash is an SST25VF016B.
A: The EC/KBC is an SMSC 1098.
Q: What is the charging IC and architecture on this motherboard?
A: The charging IC is a TI_BQ24740_QFN_28PU, and the architecture is a System Charger.
Q: What is the memory architecture on this motherboard?
A: The motherboard supports dual DDR2 SODIMM channels.
| Brand | INVENTEC |
| Model | AX2 |
| Project Code | GUCCI 2.0 |
| Board Number | 1310A2230401-0-MTR |
| Date | 23-Oct-2009 |
| CPU Platform | Intel Pineview |
| PCH / Southbridge | Intel Tigerpoint |
| GPU Type | INTEGRATED GRAPHIC |
| EC / KBC | SMSC 1098 |
| Audio Codec | ICS_92HD75B |
| BIOS / SPI Flash | SST25VF016B |
| Charging IC | TI_BQ24740_QFN_28PU |
| Charger Architecture | System Charger |
| Power IC(s) | TI_TPS51610, APL5930, TPS51125, TPS51117, TPS51100 |
| RAM Type | DDR2 |
| RAM Architecture | DUAL DDR2 CHANNEL |
| RAM Quantity / Slots | 2XDDR2_SODIMM0 |
| LAN IC | MARVEL 88E8072 |
| WiFi / WLAN IC | WLAN |
| Card Reader IC | Card Reader |
| Accelerometer | STMicro LIS302DL |
| Clock Generator | ICS9LRS3165/CK505M |
| Document Number | CSA3451AX2XXXX-XXXXXX-XX |
1310A2230401-0-MTR
Pineview
Integrated Graphic
1098
ICS_92HD75B
SST25VF016B
BQ24740_QFN_28PU
APL5930
TPS51100
TPS51117
TPS51125
TPS51610
88E8072
STMICRO LIS302DL
Motion / Position Sensor
CK505M
ICS9LRS3165
1310A2230401-0-MTR
Pineview
Integrated Graphic
1098
ICS_92HD75B
SST25VF016B
BQ24740_QFN_28PU
APL5930
TPS51100
TPS51117
TPS51125
TPS51610
88E8072
STMICRO LIS302DL
CK505M
ICS9LRS3165
