hp mini 5102 gucci20 6050a2283001-mb-x03 db-3 2009.06.24
The INVENTEC GUCCI 2.0 motherboard, project code CSA3452, board number X03, revision 2.0, dated 24-Jun-2009, is built around the Intel Pineview CPU platform paired with the Intel Tigerpoint PCH. The system uses an SMSC 1098 EC/KBC and an ICS_92HD75B audio codec. BIOS storage is handled by an ST ST25VF016B SPI flash IC. Power management is managed by a TI BQ24740 charger IC, with additional power ICs including TPS51100, TPS51117, TPS51125, and TPS51610. Memory architecture consists of dual DDR2 channels. Networking is provided by a MARVEL 88E8072 LAN/WLAN controller. The board also features a GL9755 card reader, an STMicro LIS302DL accelerometer, and an ICS9LRS3165/CK505M clock generator. The document number is 1310A2230401-0-M.
A: The BIOS SPI flash is an ST ST25VF016B.
A: The EC/KBC is an SMSC 1098.
A: The charging IC is a TI BQ24740.
A: The memory architecture is dual DDR2 channel.
Q: What is the CPU platform and PCH?
A: The CPU platform is Intel Pineview, and the PCH is Intel Tigerpoint.
| Brand | INVENTEC |
| Model | GUCCI 2.0 |
| Motherboard Manufacturer | INVENTEC |
| Project Code | CSA3452 |
| Board Number | X03 |
| Revision | 2.0 |
| Date | 24-Jun-2009 |
| CPU Platform | Intel Pineview |
| PCH / Southbridge | Intel Tigerpoint |
| EC / KBC | SMSC 1098 |
| Audio Codec | ICS_92HD75B |
| BIOS / SPI Flash | ST ST25VF016B |
| Charging IC | TI BQ24740 |
| Power IC(s) | TPS51100, TPS51117, TPS51125, TPS51610 |
| RAM Type | DDR2 |
| RAM Architecture | Dual DDR2 Channel |
| LAN IC | MARVEL 88E8072 |
| WiFi / WLAN IC | Marvel 88E8072 |
| Card Reader IC | GL9755 |
| Accelerometer | STMicro LIS302DL |
| Clock Generator | ICS9LRS3165/CK505M |
| Charger Architecture | BQ24740 |
| Graphics Architecture | Integrated Graphics |
| Document Number | 1310A2230401-0-M |
CSA3452
X03
Pineview
1098
ICS_92HD75B
ST ST25VF016B
BQ24740
TPS51100
TPS51117
TPS51125
TPS51610
88E8072
GL9755
STMICRO LIS302DL
Motion / Position Sensor
CK505M
ICS9LRS3165
Integrated Graphics )
CSA3452
X03
Pineview
1098
ICS_92HD75B
ST ST25VF016B
BQ24740
TPS51100
TPS51117
TPS51125
TPS51610
88E8072
GL9755
STMICRO LIS302DL
CK505M
ICS9LRS3165
