hp compaq presario cq60-cq70 wistron warrior intel uma_revsc schematic
hp compaq presario cq60-cq70=1=wistron warrior intel uma_revsc.pdf
The Wistron Warrior SC motherboard, project code 91.4H501.001 and board number 07239 revision SC, is an Intel UMA platform built around the Intel Penryn SV CPU and Cantiga-GM/GL integrated graphics paired with the ICH9-M southbridge. Memory architecture consists of two DDRII 667/800 slots operating in dual-channel configuration. The system is managed by a Winbond WPCE775L EC/KBC and boots from a 2MB SPI flash ROM, with a separate 64KB EC flash. Power management is handled by an ISL6269CCRZ CPU DC/DC converter, TPS51120 and TPS51116 system DC/DC converters, an SC412A regulator, and a Maxim MAX8731 charger IC. Audio is provided by a Conexant CX20561-14Z HD audio codec. Networking is supported by a Realtek RTL8101-GR Ethernet controller, and a Realtek RTS5158 card reader is integrated.
A: The motherboard uses a Winbond WPCE775L EC/KBC.
A: The motherboard uses a 2MB SPI flash ROM for the main BIOS and a separate 64KB flash ROM for the EC.
A: The motherboard supports DDRII 667/800 memory in dual-channel configuration across two slots.
Q: What charging IC is used?
A: The motherboard uses a Maxim MAX8731 charger IC.
| Model | Warrior SC |
| Project Code | 91.4H501.001 |
| Board Number | 07239 |
| Revision | SC |
| Date | Friday, January 04, 2008 |
| CPU Platform | Intel Penryn SV |
| GPU Type | Intel Cantiga-GM/GL |
| EC / KBC | Winbond WPCE775L |
| Audio Codec | Conexant CX20561-14Z |
| BIOS / SPI Flash | 2MB Flash ROM |
| EC Flash / ROM | 64KB |
| Charging IC | Maxim MAX8731 |
| Power IC(s) | ISL6269CCRZ, TPS51116, TPS51120, SC412A |
| RAM Type | DDRII 667/800 |
| LAN IC | Realtek RTL8101-GR |
| Card Reader IC | Realtek RTS5158 |
91.4H501.001
07239
Penryn
ICH9
Intel Cantiga GM
Intel Cantiga-GL
UMA
WPCE775L
CX20561-14Z
MAX8731
ISL6269CCRZ
SC412A
TPS51116
TPS51120
RTL8101-GR
RTS5158
91.4H501.001
07239
Penryn
ICH9
Intel Cantiga GM
Intel Cantiga-GL
UMA
WPCE775L
CX20561-14Z
MAX8731
ISL6269CCRZ
SC412A
TPS51116
TPS51120
RTL8101-GR
RTS5158
