hp compaq presario 2100 amd-quanta kt3i t2.2_rev3d schematic
hp compaq presario 2100=1=amd-quanta kt3i t2.2_rev3d.pdf
This Quanta Computer Inc. motherboard, project KT3IDA with board number KT3IMB6B9, is designed for the AMD Athlon/Duron CPU platform using Socket A. The system is built around the M1535+ southbridge and features an ATI-BQ325LF GPU. The embedded controller is an 87570 KBC, and the audio codec is an ALI352 BGA device. Memory configuration consists of two DDR-SODIMM slots. The board integrates an NS83816 LAN controller, an OZ6912 charging IC, an OZ6933 card reader controller, and a TSB43AB21 FireWire controller. Audio amplification is handled by the TPA0312, and system clocking is provided by the ICS94225 clock generator. The schematic was dated Wednesday, March 19, 2003.
A: The board number is KT3IMB6B9 and the project code is KT3IDA, manufactured by Quanta Computer Inc.
A: The embedded controller is an 87570 KBC.
Q: What CPU platform and socket does this motherboard support?
A: This motherboard supports the AMD Athlon/Duron CPU platform using Socket A.
A: The charging IC is an OZ6912.
Q: What LAN and FireWire controllers are integrated on this board?
A: The LAN controller is an NS83816, and the FireWire controller is a TSB43AB21.
| Project Code | KT3IDA |
| Board Number | KT3IMB6B9 |
| Date | Wednesday, March 19, 2003 |
| CPU Platform | AMD Athlon/Duron |
| CPU Socket | Socket A |
| PCH / Southbridge | M1535+ |
| GPU Type | ATI-BQ325LF |
| EC / KBC | 87570 |
| Audio Codec | ALI352 BGA |
| Charging IC | OZ6912 |
| RAM Type | DDR-SODIMM |
| LAN IC | NS83816 |
| Card Reader IC | OZ6933 |
| Audio Amplifier | TPA0312 |
| Clock Generator | ICS94225 |
| FireWire Controller | TSB43AB21 |
KT3IDA
KT3IMB6B9
Athlon
Duron
M1535+
BQ325LF
87570
ALI352
OZ6912
DDR
NS83816
OZ6933
TPA0312
ICS94225
TSB43AB21
Bridge / Expander
KT3IDA
KT3IMB6B9
Athlon
Duron
M1535+
BQ325LF
87570
ALI352
OZ6912
DDR
NS83816
OZ6933
TPA0312
ICS94225
TSB43AB21
Bridge / Expander
