hp compaq 6735 6535b inventec tt2.0 schematic
hp compaq 6735 6535b=1=inventec tt2.0.pdf
The Inventec TT20 motherboard, document number TT20CSA37011310A21501-0AX4, revision 2.0 PV1-Build A01 Final, dated 2008/04/08, is an AMD Griff platform featuring an RS780 GPU and SB700 southbridge. The system utilizes DDR2 memory architecture with two DDR II SODIMM slots. Power management is handled by a combination of TPS51117, TPS51120, MAX17009, MAX8792, and TPS51100 regulators, with charging controlled by a TI BQ24740 IC supporting 12.6V or 16.8V battery configurations. The embedded controller is a Lion/Sable KBC, and audio is provided by an ADI_1984A codec. Networking includes a BCM 5787M LAN IC and a Mini Card slot for WLAN/WiMAX. Additional I/O is managed by a SMSC USX2016 USB hub, SMSC 1091 card reader, and FW322-07-N FireWire controller, with clock generation by ICS9LPRS476KLF.
A: The charging IC is a TI BQ24740 in a QFN-28 package, supporting 12.6V charging when CELLSEL#=0 and 16.8V charging when CELLSEL#=1.
A: The embedded controller is a Lion/Sable KBC.
A: The audio codec is an ADI_1984A.
Q: What power management ICs are present on this motherboard?
A: The power management ICs include TPS51117, TPS51120, MAX17009, MAX8792, and TPS51100.
A: The motherboard uses DDR2 memory
| Brand | Inventec |
| Project Code | TT20 |
| Board Number | CSA37011310A21501-0AX4 |
| Revision | 2.0 PV1-Build A01 Final |
| Date | 2008/04/08 |
| Document Number | TT20CSA37011310A21501-0AX4 |
| CPU Platform | AMD Griff |
| PCH / Southbridge | SB700 |
| GPU Type | RS780 |
| EC / KBC | Lion / Sable |
| Audio Codec | ADI_1984A |
| BIOS / SPI Flash | BIOS |
| Charging IC | TI_BQ24740_QFN_28P |
| Charger Architecture | CELLSEL#=1,Vcharger=16.8V / CELLSEL#=0,Vcharger=12.6V |
| Power IC(s) | TPS51117, TPS51120, MAX17009, MAX8792, TPS51100 |
| RAM Type | DDR2 |
| RAM Architecture | DDR II _SODIMM0, DDR II _SODIMM1 |
| LAN IC | BCM 5787M |
| WiFi / WLAN IC | MINI CARD for WLAN(MIMO)/WiMAX |
| Card Reader IC | SMSC 1091 |
| USB Hub IC | SMSC USX2016 |
| Thermal Sensor | Thermal Sensor |
| Super I/O | Super I/O |
| Clock Generator | ICS9LPRS476KLF |
| FireWire Controller | FW322-07-N |
TT20
Griff
SB700
RS780
1984A
BQ24740_QFN_28P
MAX17009
MAX8792
TPS51100
TPS51117
TPS51120
1091
USX2016
ICS9LPRS476KLF
FW322-07-N
Bridge / Expander
TT20
Griff
SB700
RS780
1984A
BQ24740_QFN_28P
MAX17009
MAX8792
TPS51100
TPS51117
TPS51120
1091
USX2016
ICS9LPRS476KLF
FW322-07-N
Bridge / Expander
