hp compaq 520 530 550 la3491p 05 0320 mv
This Compal LA-3491P revision 0.5 schematic, dated 2007-03-20, documents a motherboard designed around the Mobile Yonah/Merom uFCPGA-478 CPU platform with Intel Calistoga_GM+ ICH7-M core logic. The graphics architecture is based on Intel 945GM or 940GML MCH. System memory consists of two DDR2 SO-DIMM slots supporting dual-channel DDR2-400/533/667. The embedded controller is an SMSC KBC 1070. The BIOS SPI flash is a 25LF080A SPI ROM. Audio is handled by a Conexant CX20549-12 codec with a TPA6017A2 amplifier. Networking is provided by an Intel 82562V 10/100 LAN controller. Thermal monitoring uses an ADM1032AR sensor. The platform also includes a CardBus controller (CB-1410) and a clock generator (ICS9LP306BGLF).
A: The BIOS SPI flash is a 25LF080A SPI ROM.
A: The embedded controller is an SMSC KBC 1070.
Q: What is the CPU socket and platform for this motherboard?
A: The CPU platform is Mobile Yonah/Merom with a uFCPGA-478 socket, using Intel Calistoga_GM+ ICH7-M core logic.
A: The motherboard supports dual-channel DDR2-400/533/667 memory via two DDR2 SO-DIMM slots.
| Document Number | LA-3491P |
| Revision | 0.5 |
| Date | 2007-03-20 |
| CPU Platform | Mobile Yonah uFCPGA with Intel Calistoga_GM+ ICH7-M core logic |
| CPU Socket | uFCPGA-478 |
| PCH / Southbridge | Intel ICH7-M |
| GPU Type | Intel Calistoga MCH |
| Graphics Architecture | Intel 945GM / 940GML |
| EC / KBC | SMSC KBC 1070 |
| Audio Codec | Conexant CX20549-12 |
| BIOS / SPI Flash | 25LF080A |
| BIOS Flash Exact Model | 25LF080A |
| BIOS Flash Package | SPI ROM |
| RAM Type | DDR2 |
| RAM Quantity / Slots | DDR2-SO-DIMM X2 |
| Thermal Sensor | ADM1032AR |
| LAN IC | Intel 82562V 10/100 |
| WiFi / WLAN IC | Mini-Card WLAN |
