Schematic HP 250 G9 IPA50 LA-K203P Schematic
BrandCompal
ModelTGL-U
Project CodeLA-K203P
Board NumberLA-K203P
Revision1.0
Date2020-07-26
CPU PlatformTGL-U
EC / KBCENE KB9052Q
Audio CodecALC3247-CG
BIOS / SPI Flash16MBytes
LAN ICRTL8111HSH-CG
Card Reader ICAK6485RB63-GLF-GR
Thermal SensorG753T11U
TPMSLB9670VQ2.0
RAM TypeDDR4 3200MHz 1.2V
RAM ArchitectureDual Channel Interleaved
RAM Quantity / SlotsDDR4-SO-DIMM X2
This Compal LA-K203P schematic, revision 1.0 dated 2020-07-26, documents the TGL-U platform motherboard. The board is built around a TGL-U CPU platform with DDR4 3200MHz 1.2V memory configured as dual channel interleaved across two DDR4-SO-DIMM slots. The embedded controller is an ENE KB9052Q. Audio is handled by a Realtek ALC3247-CG codec. The system BIOS is stored on a 16MBytes SPI ROM. Wired networking is provided by a Realtek RTL8111HSH-CG LAN IC. A card reader controller AK6485RB63-GLF-GR is present. Thermal monitoring is managed by a G753T11U sensor. The board also includes an Infineon SLB9670VQ2.0 TPM module.
A: The board number and project code are both LA-K203P.
A: The embedded controller is an ENE KB9052Q.
A: This motherboard supports DDR4 3200MHz 1.2V memory in a dual channel interleaved configuration across two DDR4-SO-DIMM slots.
A: The audio codec is a Realtek ALC3247-CG.
A: The LAN IC is a Realtek RTL8111HSH-CG.
  • HP 250 G9 IPA50 LA-K203P Schematic.pdf
