Gigabyte X570 AORUS PRO WIFI Rev 1.0 1.01 1.1 1.02 1.2 1.11 Schematic
The Gigabyte X570 AORUS PRO WIFI motherboard, documented under Document Number U98126-02 Revision 1.0 dated Tuesday, May 14, 2019, is built on the AMD X570 platform. The audio subsystem is managed by an ALC1220-VB2 CODEC. Networking is provided by an Intel WGI211AT LAN IC and an Intel 9260 WiFi/WLAN module. The embedded controller is an IT8795, with an IT8688E Super I/O for hardware monitoring. USB connectivity is expanded via a GL850S USB hub IC, and signal redriving is handled by a PI3EQX1002B1ZLE. An IT8297 MCU is also present on the board.
Q: What is the document number and revision for this motherboard?
A: The document number is U98126-02, Revision 1.0, dated Tuesday, May 14, 2019.
Q: What EC/KBC and Super I/O controllers are used?
A: The embedded controller is an IT8795, and the Super I/O is an IT8688E.
Q: What audio codec is used on this board?
A: The audio codec is an ALC1220-VB2 CODEC.
Q: What LAN and WiFi controllers are used?
A: The LAN controller is an Intel WGI211AT, and the WiFi module is an Intel 9260.
The Gigabyte X570 AORUS PRO WIFI motherboard, documented under revision 1.01 with document number U98126-02, is built on the AMD X570 platform. The system is managed by an IT8795 EC/KBC, with audio processing handled by the ALC1220-VB2 codec. Networking is provided by an Intel WGI211AT LAN controller and an Intel 9260 WiFi module. The design incorporates an IT8688E Super I/O, an IT8297 MCU, and a GL850 USB hub IC. Signal redriving is managed by the PI3EQX1002B1ZLE, while voltage regulation is controlled by the IR35201 PWM controller.
A: The motherboard uses an IT8795 EC/KBC.
A: The audio codec is the ALC1220-VB2.
Q: What LAN and WiFi controllers are used on this motherboard?
This Gigabyte X570 AORUS PRO WIFI motherboard, revision 1.02 with project code U98126-02, is built on the AMD X570 platform. The board utilizes an IT8795 EC/KBC and an IT8688E Super I/O for system management. Audio is handled by the Realtek ALC1220-VB2 codec, while networking is provided by an Intel WGI211AT LAN controller and an Intel 9260 WiFi module. The design incorporates a GL850S USB 2.0 hub and a PI3EQX1002B1ZLE redriver for signal integrity. An IT8297 MCU is present for additional control functions, and the PWM regulation is managed by an IR35201 controller. The board's BOM and PCB history document multiple revisions and component changes throughout its development cycle.
Q: What is the project code and board number for this motherboard?
A: The project code and board number is U98126-02.
A: The EC/KBC is an IT8795, and the Super I/O is an IT8688E.
Q: What audio codec and LAN controller are on this board?
A: The audio codec is a Realtek ALC1220-VB2, and the LAN controller is an Intel WGI211AT.
The Gigabyte X570 AORUS PRO WIFI motherboard, documented under revision 1.1 with document number U98126-02, is built on the AMD X570 platform. The audio subsystem is driven by an ALC1220-VB2 codec. Networking is handled by an Intel WGI211AT LAN controller and an Intel 9260 WiFi module. The embedded controller is an IT8795, complemented by an IT8688E Super I/O and an IT8297 MCU. USB connectivity is managed by a GL850 hub IC, with signal redriving provided by a PI3EQX1002B1ZLE. The charging IC is an RTS5441, and the primary power controller is an IR35201. The board supports dual BIOS configurations and includes a THB_C header.
Q: What audio codec is used on the X570 AORUS PRO WIFI?
A: The motherboard uses an ALC1220-VB2 CODEC.
Q: What LAN and WiFi controllers are present?
Q: What embedded controller and Super I/O are used?
A: The EC is an IT8795, and the Super I/O is an IT8688E.
A: The charging IC is an RTS5441.
| Brand | Gigabyte |
| Model | X570 AORUS PRO WIFI |
| Document Number | U98126-02 |
| Date | Tuesday, May 14, 2019 |
| CPU Platform | AMD X570 |
| Audio Codec | alc1220-vb2-codec/"]ALC1220-VB2 CODEC[/URL] |
| LAN IC | INTEL WGI211AT |
| EC / KBC | IT8795 |
| Super I/O | IT8688E |
| USB Hub IC | GL850S |
| Redriver | PI3EQX1002B1ZLE |
| WiFi / WLAN IC | Intel 9260 |
| MCU | IT8297 |
| Brand | Gigabyte |
| Revision | 1.01 |
| Date | Wednesday, June 05, 2019 |
| PCH / Southbridge | X570 |
| EC / KBC | IT8795 |
| Audio Codec | ALC1220-VB2 |
| LAN IC | Intel WGI211AT |
| USB Hub IC | GL850 |
| MCU | IT8297 |
| PWM Controller | IR35201 |
| Brand | Gigabyte |
| Motherboard Manufacturer | Gigabyte |
| Project Code | U98126-02 |
| Board Number | U98126-02 |
| Revision | 1.02 |
| Date | Monday, July 22, 2019 |
| PCH / Southbridge | AMD X570 |
| EC / KBC | IT8795 |
| MCU | IT8297 |
| Brand | Gigabyte |
| Revision | 1.1 |
| Date | Monday, September 16, 2019 |
| EC / KBC | IT8795 |
| Charging IC | RTS5441 |
| Power IC(s) | IR35201 |
| MCU | IT8297 |
| Brand | Gigabyte |
| Revision | 1.11 |
| Date | Tuesday, February 18, 2020 |
| EC / KBC | IT8795 |
| MCU | IT8297 |
| Charging IC | Not explicitly present in source |
| Power IC(s) | Not explicitly present in source |
| RAM Quantity / Slots | Not explicitly present in source |
| Thermal Sensor | Not explicitly present in source |
| Card Reader IC | Not explicitly present in source |
| HDMI Level Shifter | Not explicitly present in source |
| BIOS / SPI Flash | Not explicitly present in source |
| BIOS Flash Exact Model | Not explicitly present in source |
| BIOS Flash Manufacturer | Not explicitly present in source |
| BIOS Flash Capacity | Not explicitly present in source |
| BIOS Flash Package | Not explicitly present in source |
| Compatible BIOS IC Models | Not explicitly present in source |
| EC Flash / ROM | Not explicitly present in source |
| Charger Architecture | Not explicitly present in source |
| GPU Type | Not explicitly present in source |
| Graphics Architecture | Not explicitly present in source |
| dGPU Chip Number | Not explicitly present in source |
| dGPU to UMA Conversion Support | Not explicitly present in source |
| CPU Model | Not explicitly present in source |
| CPU Socket | Not explicitly present in source |
| PCH / Southbridge | Not explicitly present in source |
| Platform Alias | Not explicitly present in source |
| Motherboard Manufacturer | Not explicitly present in source |
| Project Code | Not explicitly present in source |
| Board Number | Not explicitly present in source |
| MLB Identifier | Not explicitly present in source |
| Drawing Number | Not explicitly present in source |
| 820- Board Number | Not explicitly present in source |
| 051- Drawing Number | Not explicitly present in source |
| PCB Number | Not explicitly present in source |
| Schematic Number | Not explicitly present in source |
