Schematic Gigabyte X570 AORUS EXTREME Rev 1.0 1.01 1.1 Schematic
BrandGigabyte
ModelX570 AORUS XTREME
Motherboard ManufacturerGigabyte
Document NumberU98126-02
Revision1.0
DateMonday, May 13, 2019
CPU PlatformAMD AM4
PCH / SouthbridgePromontory
EC / KBCIT8795 EC1
EC / KBCIT8795 EC2
Audio CodecALC1220
Audio Codecess9218pq-dac/"]ESS9218PQ_DAC[/URL]
Charging ICRT5423
Power IC(s)XDPE132G5C
Power IC(s)tda21472-mos-1-4/"]TDA21472_MOS_1-4[/URL]
Power IC(s)RT8120
Power IC(s)NCT3103S
Power IC(s)RT8068A
RAM TypeDDR4
RAM ArchitectureUNBUFFERED DDR4 DIMM
RAM Quantity / Slots4
LAN ICINTEL I211AT
LAN ICaqc107-1-2-3/"]AQC107-1/2/3[/URL]
WiFi / WLAN ICintel 9260
Card Reader ICRTS5441
USB Hub ICRTS5423
Super I/OIT8688A
Super I/OIT8688E
Thermal SensorNCT3933
BIOS / SPI FlashSPI BIOS
GPU TypedGPU
Graphics ArchitecturePCIe Gen4 x16
The Gigabyte X570 AORUS XTREME motherboard, document number U98126-02 revision 1.0, is built on the AMD AM4 platform with a Promontory PCH. The board features dual IT8795 EC controllers (EC1 and EC2) for embedded control. Audio is handled by an ALC1220 HD audio codec and an ESS9218PQ DAC. Power management includes an XDPE132G5C controller with TDA21472 MOSFETs, alongside RT8120, NCT3103S, and RT8068A regulators. Memory configuration supports four unbuffered DDR4 DIMM slots. Networking is provided by an Intel I211AT 1G LAN and AQC107 2.5G LAN controllers, with an Intel 9260 WiFi module. The system uses an SPI BIOS flash for firmware storage. The board also integrates an IT8688A and IT8688E Super I/O, an RTS5441 card reader, an RTS5423 USB hub, and an NCT3933 thermal sensor.
Q: What EC/KBC controllers are used on this motherboard?
A: This motherboard uses two IT8795 EC controllers, designated EC1 and EC2.
Q: What audio codecs are present on this board?
A: The board features an ALC1220 HD audio codec and an ESS9218PQ DAC.
Q: What LAN controllers are used on the X570 AORUS XTREME?
A: The board uses an Intel I211AT 1G LAN controller and an AQC107 2.5G LAN controller.
Q: What is the
BrandGigabyte
Revision1.01
DateWednesday, July 24, 2019
CPU PlatformAMD AM4
PCH / SouthbridgeAMD X570
EC / KBCIT8795 EC1
EC / KBCIT8795 EC2
Audio Codecalc1220-codec/"]ALC1220 CODEC[/URL]
Charging ICRT5423
Power IC(s)RT8120
Power IC(s)NCT3103S
Power IC(s)RT8068A
RAM TypeDDR4
RAM Quantity / Slots4 DIMM
LAN ICINTEL I211AT
LAN ICAQC107
WiFi / WLAN ICIntel 9260
USB Hub ICRTS5423
Super I/OIT8688
Super I/OIT8795 EC1
Super I/OIT8795 EC2
The Gigabyte X570 AORUS XTREME motherboard, documented under revision 1.01 with document number U98126-02, is built on the AMD AM4 platform with an AMD X570 chipset. The board utilizes dual IT8795 embedded controllers (EC1 and EC2) for system management. Audio processing is handled by an ALC1220 HD audio codec and an ESS9218PQ DAC. Power delivery is managed by an XDPE132G5C PWM controller paired with TDA21472 MOSFETs, alongside RT8120, NCT3103S, and RT8068A regulators for memory power. The board supports four unbuffered DDR4 DIMM slots. Networking is provided by an Intel I211AT 1GbE LAN controller and an AQC107 2.5GbE LAN controller, with wireless connectivity via an Intel 9260 module. Additional I/O includes an RTS5423 USB hub controller and an RTS5441 card reader controller, with an IT8688 Super I/O for legacy hardware monitoring.
Q: What embedded controllers are used on this motherboard?
A: This motherboard uses two IT8795 embedded controllers, designated EC1 and EC2.
A: The board uses an Intel I211AT 1GbE controller and an AQC107 2.5GbE controller.
Q: What power management ICs are used for CPU and memory?
A: CPU power is managed by an XDPE132G5C PWM controller with TDA21472 MOSFETs. Memory power uses an RT8120 for VDDIO_MEM, an NCT3103S for DDRVTT, and an RT8068A for DDRVPP.
BrandGigabyte
Revision1.1
DateTuesday, September 24, 2019
CPU PlatformAMD AM4
PCH / SouthbridgeAMD X570 (Promontory)
EC / KBCIT8795 EC1
EC / KBCIT8795 EC2
Audio CodecALC1220
Audio CodecESS9218PQ
Charging ICRT5423
Power IC(s)TDA21472
Power IC(s)RT8120
Power IC(s)NCT3103S
Power IC(s)RT8068A
RAM TypeDDR4
LAN ICINTEL I211AT
LAN ICAQC107
USB Hub ICRTS5423
Card Reader ICRTS5441T
Super I/OIT8688
HDMI Level ShifterITE IT8795
The Gigabyte X570 AORUS XTREME motherboard, document number U98126-02 revision 1.1 dated September 24, 2019, is built on the AMD AM4 platform with the AMD X570 Promontory chipset. The board utilizes dual IT8795 EC controllers (EC1 and EC2) for embedded control. Audio processing is handled by an ALC1220 HD audio codec and an ESS9218PQ DAC. Power management is managed by a XDPE132G5C PWM controller paired with TDA21472 MOSFETs, alongside RT8120, NCT3103S, and RT8068A regulators for DDR4 memory power. The board supports four unbuffered DDR4 DIMM slots. Networking is provided by an Intel I211AT 1G LAN controller and an AQC107 2.5G/5G LAN controller, with wireless connectivity via an Intel 9260 module. USB connectivity is expanded through an RTS5423 hub, and a RTS5441T controller handles Type-C and card reader functions. System monitoring and I/O are managed by an IT8688 Super I/O, with thermal monitoring via an NCT3933 sensor.
A: The board features an ALC1220 HD audio codec and an ESS9218PQ DAC for audio processing.
A: The board uses an Intel I211AT 1G LAN controller and an AQC107 2.5G/5G LAN controller.
A: CPU power is managed by a XDPE132G5C PWM controller with TDA21472 MOSFETs, while memory power uses RT8120, NCT3103S, and RT8068A regulators.
  • Gigabyte X570 AORUS EXTREME Rev 1.0 Schematic.pdf
  • Gigabyte X570 AORUS EXTREME Rev 1.01 Schematic.pdf
  • Gigabyte X570 AORUS EXTREME Rev 1.1 Schematic.pdf
