gigabyte ga-z87x-d3h rev 1.11
The Gigabyte GA-Z87X-D3H revision 1.11 motherboard is built on the Intel LGA1150 Haswell platform with an Intel Z87 Lynx Point PCH. The board utilizes a SPI Dual BIOS configuration with 64M flash capacity. System management is handled by an ITE ITE8728 EC/KBC, while audio is provided by a Realtek ALC892 codec. Networking is supported by an Intel I217 LAN IC. USB 3.0 connectivity is managed by a Renesas UPD720210 hub controller. The memory architecture consists of four DDRIII DIMM slots arranged in two channels of two slots each. Power regulation is handled by an IR3563B PWM controller, IR3550 VCORE, IR3570 DDR PWM, and IR3598 DDR components. A TI H/W charger IC is present. The HDMI interface uses a PTN3360DBS level shifter, and an ITE ITE8892 PCI bridge manages card reader functionality.
Q: What BIOS IC configuration is used on this motherboard?
A: The GA-Z87X-D3H uses a SPI Dual BIOS configuration with 64M flash capacity.
A: The board uses an ITE ITE8728 EC/KBC controller.
Q: What is the charging IC architecture on this motherboard?
A: The board uses a TI H/W charger IC.
A: The board supports DDRIII memory with four DIMM slots configured as two channels of two slots each.
| Model | GA-Z87X-D3H |
| Board Number | 9MZ87XD3H-00-11B |
| Revision | 1.11 |
| Date | Monday, December 09, 2013 |
| CPU Platform | Intel LGA1150 (Haswell) |
| PCH / Southbridge | Intel Z87 (Lynx Point) |
| EC / KBC | ITE ITE8728 |
| Audio Codec | Realtek ALC892 |
| BIOS / SPI Flash | SPI Dual BIOS (64M) |
| LAN IC | Intel I217 |
| USB Hub IC | Renesas UPD720210 |
| RAM Architecture | DDRIII DIMM X 2 / DDRIII DIMM X 2 |
| RAM Quantity / Slots | 4 |
| Charging IC | TI H/W charger |
| Power IC(s) | IR3563B_PWM / IR3550-VCORE / IR3570_DDR PWM / IR 3598-DDR |
| Card Reader IC | ITE ITE8892 |
| HDMI Level Shifter | PTN3360DBS/HVQFN48 |
9MZ87XD3H-00-11B
Haswell
Z87
IT8728
ALC892
I217
UPD720210
IR3563B_PWM
IR3570-DDR
IR3598-DDR
IT8892
HVQFN48
PTN3360DBS
9MZ87XD3H-00-11B
Haswell
Z87
IT8728
ALC892
I217
UPD720210
IR3563B_PWM
IR3570-DDR
IR3598-DDR
IT8892
HVQFN48
PTN3360DBS
