gigabyte ga-z87x-d3h rev 1.1
The Gigabyte GA-Z87X-D3H Rev 1.1 motherboard is built on the Intel LGA1150 (Haswell) platform with a Lynx Point (Z87/H87) PCH. It features a SPI Dual BIOS configuration with 64M capacity and an ITE8728 EC/KBC controller. Memory architecture consists of four DDRIII DIMM slots arranged as two per channel. The audio subsystem is driven by a Realtek ALC892 codec, while networking is handled by an Intel I217 LAN IC. USB 3.0 connectivity is provided by a RENESAS UPD720210 hub controller, and an ITE8892 PCI bridge manages card reader functions. Power regulation includes IR3563B_PWM, IR3550-VCORE, IR3570_DDR PWM, and IR3598-DDR ICs. The HDMI level shifter was revised from PTN3360DBS to ASM1442. The board number is 9MZ87XD3H-00-10B, dated July 22, 2013.
A: The motherboard uses a SPI Dual BIOS configuration with 64M capacity.
Q: What EC/KBC controller is used?
A: The motherboard uses an ITE8728 LPC I/O controller.
A: The motherboard supports DDRIII memory with four DIMM slots, configured as two per channel (Channel A and Channel B).
Q: What LAN IC is used?
A: The motherboard uses an Intel I217 LAN controller.
Q: What USB 3.0 hub controller is used?
A: The motherboard uses a RENESAS UPD720210 4-port hub controller.
| Model | GA-Z87X-D3H |
| Board Number | 9MZ87XD3H-00-10B |
| Revision | 1.1 |
| Date | Monday, July 22, 2013 |
| CPU Platform | Intel LGA1150 (Haswell) |
| PCH / Southbridge | Lynx Point (Z87/H87) |
| EC / KBC | ITE8728 |
| Audio Codec | Realtek ALC892 |
| BIOS / SPI Flash | SPI Dual BIOS (64M) |
| LAN IC | Intel I217 |
| USB Hub IC | RENESAS UPD720210 |
| Card Reader IC | ITE8892 PCI Bridge |
| RAM Architecture | DDRIII DIMM X 2 (Channel A), DDRIII DIMM X 2 (Channel B) |
| RAM Quantity / Slots | 4 |
| Charging IC | TI H/W charger |
| HDMI Level Shifter | PTN3360DBS/HVQFN48 (changed to ASM1442/QFN48) |
| Power IC(s) | IR3563B_PWM, IR3550-VCORE, IR3570_DDR PWM, IR3598-DDR |
| GPU Type | Intel HD Graphics (Haswell integrated) |
| Graphics Architecture | Display: DVI, HDMI, RGB |
9MZ87XD3H-00-10B
Haswell
H87
Z87
IT8728
ALC892
I217
UPD720210
IT8892 PCI BRIDGE
HVQFN48 (CHANGED TO ASM1442
PTN3360DBS
QFN48)
IR3563B_PWM
IR3570-DDR
IR3598-DDR
Intel HD Graphics
9MZ87XD3H-00-10B
Haswell
H87
Z87
IT8728
ALC892
I217
UPD720210
IT8892 PCI BRIDGE
PTN3360DBS
QFN48)
IR3563B_PWM
IR3570-DDR
IR3598-DDR
Intel HD Graphics
