Schematic Gigabyte GA-Z170M-Hero Rev 1.0 Schematic
BrandGigabyte Technology
ModelGA-Z170M-HERO
Motherboard ManufacturerGigabyte Technology
Board NumberGA-Z170M-HERO
Revision1.0
DateTuesday, July 28, 2015
CPU PlatformIntel LGA1151 (Skylake)
PCH / SouthbridgeZ170/H170
EC / KBCITE 8628
Audio CodecRealtek ALC892
BIOS / SPI FlashSPI Dual BIOS (64M)
LAN ICIntel I219V
RAM TypeDDR4
RAM ArchitectureDDR4 DIMM X 2
RAM Quantity / SlotsDDR4 DIMM X 2
HDMI Level ShifterPTN3356
Card Reader ICASM1083
USB Hub ICASM1083
Charging ICISL95858_856
Power IC(s)ISL95858_856, RT8120_DDR_VDDQ, RT8068A_VPP_25V, RT8120_PCH_VCC1_0_PCH
GPU Type[URL="https://dr-bios.com/components/graphics-models/intel-lga1151-skylake/"]Intel LGA1151 (Skylake)[/URL]
Graphics ArchitectureIntel LGA1151 (Skylake)
Thermal SensorNCT3933
The Gigabyte GA-Z170M-HERO revision 1.0 motherboard, dated July 28, 2015, is built on the Intel LGA1151 (Skylake) CPU platform with a Z170/H170 PCH. The board features a dual BIOS configuration utilizing SPI 64M flash memory. System management is handled by an ITE 8628 EC/KBC, while audio is provided by a Realtek ALC892 codec. Networking is supported by an Intel I219V LAN IC. The memory architecture consists of two DDR4 DIMM slots. Power regulation includes ISL95858_856, RT8120_DDR_VDDQ, RT8068A_VPP_25V, and RT8120_PCH_VCC1_0_PCH ICs. The board incorporates an ASM1083 PCI bridge functioning as a card reader and USB hub controller. Display connectivity is managed through a PTN3356 DP to VGA converter. Thermal monitoring is handled by an NCT3933 sensor.
A: The GA-Z170M-HERO uses a SPI Dual BIOS configuration with 64M flash capacity.
A: The board uses an ITE 8628 LPC I/O controller as the EC/KBC.
Q: What is the LAN IC on this motherboard?
A: The board uses an Intel I219V PHY for networking.
A: The board uses a Realtek ALC892 codec.
  • Gigabyte GA-Z170M-Hero Rev 1.0 Schematic.pdf
