Gigabyte GA-X170-EXTREME ECC Rev 1.0 Schematic
The Gigabyte GA-X170-Extreme ECC motherboard, revision 1.0, is built on the Intel LGA1151 Skylake platform with a PCH (Z170/H170) southbridge. It features a Dual BIOS configuration with 128M capacity, managed by an ITE 8620 LPC I/O EC/KBC. The board supports DDR4 memory across two channels, each with two DIMM slots. Graphics architecture includes PCI Express X16 and X8 slots with switching capability. Networking is handled by a Killer E2201 and Intel i219V LAN ICs, with Alpine Ridge for wireless connectivity. Power management utilizes ISL95856 PWM controllers and RT8120 regulators. The audio subsystem is driven by a Creative Sound3Di codec. Additional controllers include an ASM1061 SATA III controller, D720210 USB hub, MCDP2800-BA HDMI level shifter, and IDT6V41510 clock buffer. The board also incorporates NTC thermal sensors and supports dGPU via MVP 8C.
A: The motherboard uses a Dual BIOS configuration with 128M capacity. The exact IC models are not explicitly listed in the source.
A: The EC/KBC is an ITE 8620 LPC I/O. The source does not explicitly indicate programmable capability.
Q: What is the charging architecture on this motherboard?
A: The charging architecture uses ISL95856 PWM controllers and RT8120 regulators for power management.
A: The motherboard supports DDR4 memory across two channels, DDR4 CHANNEL A and DDR4 CHANNEL B, each with two DIMM slots.
| Model | GA-X170-Extreme ECC |
| Board Number | 9MX17GA7W-00-10A |
| Date | Thursday, February 18, 2016 |
| CPU Platform | Intel LGA1151 (Skylake) |
| PCH / Southbridge | PCH (Z170/H170) |
| EC / KBC | ITE 8620 |
| EC/KBC Package | LPC I/O |
| Audio Codec | Creative Sound3Di |
| BIOS / SPI Flash | Dual BIOS |
| BIOS Flash Capacity | 128M |
| Charging IC | ISL95856 |
| Power IC(s) | ISL95856 PWM, RT8120, RT8120_PCH |
| RAM Architecture | DDR4 CHANNEL A 1,2, DDR4 CHANNEL B 1,2 |
| RAM Quantity / Slots | DDR4 DIMM X 2, DDR4 DIMM X 2 |
| LAN IC | Killer E2201, Intel i219V |
| WiFi / WLAN IC | Alpine Ridge |
| HDMI Level Shifter | MCDP2800-BA |
| Card Reader IC | ASM1061 |
| USB Hub IC | D720210 |
| GPU Type | MVP 8C |
| Graphics Architecture | PCI EXPRESS X16 SWITCH, PCI EXPRESS X8 SLOT, PCI EXPRESS X16 SLOT |
| Thermal Sensor | NTC |
| CLK Buffer | IDT6V41510 |
9MX17GA7W-00-10A
Skylake
H170
Z170
8620
CREATIVE SOUND3DI
ISL95856
ISL95856
RT8120
RT8120_PCH
I219V
KILLER E2201
MCDP2800-BA
ASM1061
D720210
MVP 8C
9MX17GA7W-00-10A
Skylake
H170
Z170
8620
CREATIVE SOUND3DI
ISL95856
ISL95856
RT8120
RT8120_PCH
I219V
KILLER E2201
MCDP2800-BA
ASM1061
D720210
MVP 8C
