gigabyte ga-h61m-s2-b3_rev_1.0_dr-bios.com gigabyte ga-h61m-s2-b3_rev_1.0_dr-bios.com schematic
gigabyte=ga-h61m-s2-b3 rev 1.0.pdf
The Gigabyte GA-H61M-S2-B3 motherboard, revision 1.0, is built around the Intel H61 PCH and supports the Intel LGA1155 CPU platform. The board utilizes DDRIII memory across two channels, each with a single DIMM slot. System management is handled by an ITE8728 LPC I/O controller, while audio is provided by the ALC888B-VD2 codec and networking by the RTL8111E 1Gb LAN IC. Power regulation is managed by multiple ISL6364 controllers and an ISL95870 for CPU VTT. The board includes a Dual BIOS feature and an RGB display output. The board number is 9MH61MS2V-00-01, with a document date of May 25, 2011.
Q: What is the board number for the Gigabyte GA-H61M-S2-B3?
A: The board number is 9MH61MS2V-00-01.
A: The EC/KBC controller is the ITE8728 LPC I/O.
Q: What audio codec is used on the GA-H61M-S2-B3?
A: The audio codec is the ALC888B-VD2.
A: The LAN IC is the RTL8111E 1Gb LAN.
| Model | GA-H61M-S2-B3 |
| Board Number | 9MH61MS2V-00-01 |
| Date | Wednesday, May 25, 2011 |
| CPU Platform | Intel LGA1155 |
| PCH / Southbridge | H61 |
| EC / KBC | ITE8728 |
| Audio Codec | ALC888B-VD2 |
| LAN IC | RTL8111E |
| RAM Architecture | DDRIII DIMM X 1 per channel |
| RAM Quantity / Slots | 2 (Channel A and Channel B) |
| Charging IC | ISL6364_1, ISL6364_2, ISL6364_3 |
| Power IC(s) | ISL95870_CPU_VTT |
| Graphics Architecture | RGB Display |
