gigabyte ga-h61m-d2h_rev_1.0_dr-bios.com gigabyte ga-h61m-d2h_rev_1.0_dr-bios.com schematic
gigabyte=ga-h61m-d2h rev 1.0.pdf
The Gigabyte GA-H61M-D2H revision 1.0 motherboard, documented on August 25, 2011, is built around the Intel LGA1155 CPU platform paired with the Intel H61 PCH. The board utilizes DDRIII memory across four DIMM slots, configured as one DIMM per channel on Channel A and Channel B. Graphics output is supported via RGB, DVI, and HDMI interfaces. The system incorporates a DUAL BIOS architecture for firmware redundancy. Key onboard controllers include the ITE 8728 EC/KBC, an ALC889 audio codec, an Atheros AR8151 Gigabit LAN IC, an Etron USB3.0 3232 hub controller, an ITE 8892E card reader, and a Marvell 9172 wireless module. Power management is handled by an ATX architecture with discrete voltage regulation provided by ISL95870 and three ISL6364 controllers. The board number is 9MH61MUB3-00-10B.
A: The motherboard uses an ITE 8728 EC/KBC.
Q: What BIOS architecture is used on this motherboard?
A: This motherboard features a DUAL BIOS architecture.
A: The board supports DDRIII memory with four DIMM slots, configured as one DIMM per channel on Channel A and Channel B.
Q: What are the primary power management ICs on this board?
A: The board uses an ISL95870 and three ISL6364 controllers (ISL6364_2, ISL6364_3, ISL6364_1) for voltage regulation.
| Model | GA-H61M-D2H |
| Board Number | 9MH61MUB3-00-10B |
| Date | Thursday, August 25, 2011 |
| CPU Platform | Intel LGA1155 |
| PCH / Southbridge | PCH (H61) |
| EC / KBC | ITE 8728 |
| Audio Codec | ALC889 |
| LAN IC | Atheros AR8151 |
| USB Hub IC | Etron USB3.0 3232 |
| Card Reader IC | ITE 8892E |
| WiFi / WLAN IC | Marvell 9172 |
| RAM Architecture | DDRIII DIMM X 1 (Channel A), DDRIII DIMM X 1 (Channel B) |
| RAM Quantity / Slots | 4 DIMM |
| Graphics Architecture | RGB, DVI, HDMI |
| Charger Architecture | ATX |
| Power IC(s) | ISL95870, ISL6364_2, ISL6364_3, ISL6364_1 |
| BIOS / SPI Flash | DUAL BIOS |
| Document Number | Custom133 |
