gateway lt31 quanta za8_rev1a schematic
gateway lt31=1=quanta za8_rev1a.pdf
The Quanta ZA8 project is an AMD S1g1 platform motherboard built around the RS690E graphics and SB600 southbridge. System memory is DDR II 667 MHz via DDRII-SODIMM slots. The embedded controller is an EC 775, and the BIOS is stored on a FlashROM SPI device. Audio is handled by an ALC272 Azalia codec, and networking by a Realtek RTL8103EL 10/100 LAN controller. Power management includes an ISL88731 charger IC, along with ISL6237, ISL6264A, UP6111AQDD, TPS51160, and RT9025 regulators. A G781 thermal sensor provides temperature monitoring, and a Realtek RTS5159B controller manages the 4-in-1 card reader. The block diagram also indicates support for a Mini Card WLAN module.
A: The embedded controller is an EC 775.
Q: What BIOS flash type is used?
A: The BIOS is stored on a FlashROM SPI device.
A: The charging IC is an ISL88731.
Q: What is the audio codec used?
A: The audio codec is an ALC272.
| Project Code | ZA8 |
| Date | Friday, May 08, 2009 |
| CPU Platform | AMD S1g1 |
| PCH / Southbridge | SB600 |
| GPU Type | RS690E |
| EC / KBC | 775 |
| Audio Codec | ALC272 |
| BIOS / SPI Flash | FlashROM SPI |
| Charging IC | ISL88731 |
| Power IC(s) | ISL6237, ISL6264A, UP6111AQDD, TPS51116, RT9025 |
| RAM Type | DDRII-SODIMM |
| RAM Architecture | DDR II 667 MHz |
| Card Reader IC | RTS5159B |
| LAN IC | RTL8103EL |
| WiFi / WLAN IC | Mini Card (WLAN) |
| Thermal Sensor | G781 |
ZA8
S1G1
SB600
RS690E
775
ALC272
ISL88731
ISL6237
ISL6264A
RT9025
TPS51116
UP6111AQDD
RTS5159B
RTL8103EL
G781
ZA8
S1G1
SB600
RS690E
775
ALC272
ISL88731
ISL6237
ISL6264A
RT9025
TPS51116
UP6111AQDD
RTS5159B
RTL8103EL
G781
