gateway quanta za8 rs690e mb b2a 20090410 1
The Quanta ZA8 project, dated April 10, 2009, is built around the AMD S1g1 CPU platform with an SB600 southbridge and RS690EWPCE graphics. The system uses DDR II 667 MHz memory in a DDRII-SODIMM architecture. Power management is handled by an ISL88731 charger, with additional power ICs including ISL6237, ISL6264A, UP6111AQDD, TPS51116, and RT9025. The embedded controller is an EC 775. Audio is provided by an ALC272 codec, and networking by a Realtek RTL8103EL LAN IC with a Mini Card (WLAN) for wireless connectivity. A Realtek RTS5159B card reader controller is present, and thermal monitoring is managed by a G781 sensor.
Q: What is the CPU platform and southbridge used on this motherboard?
A: The CPU platform is AMD S1g1, paired with an SB600 southbridge.
Q: What is the embedded controller (EC) on this board?
A: The EC is an EC 775.
Q: What charging IC and power management ICs are used?
A: The charging IC is ISL88731. Power ICs include ISL6237, ISL6264A, UP6111AQDD, TPS51116, and RT9025.
Q: What audio codec and LAN IC are present?
A: The audio codec is ALC272, and the LAN IC is RTL8103EL.
| Project Code | ZA8 |
| Date | Friday, April 10, 2009 |
| CPU Platform | AMD S1g1 |
| PCH / Southbridge | SB600 |
| GPU Type | RS690EWPCE |
| Graphics Architecture | Azalia 465 FCBGA |
| EC / KBC | 775 |
| Audio Codec | ALC272 |
| Charging IC | ISL88731 |
| Power IC(s) | ISL6237, ISL6264A, UP6111AQDD, TPS51116, RT9025 |
| RAM Type | DDR II 667 MHz |
| RAM Architecture | DDRII-SODIMM |
| Card Reader IC | RTS5159B |
| LAN IC | RTL8103EL |
| WiFi / WLAN IC | Mini Card (WLAN) |
| Thermal Sensor | G781 |
| Charger Architecture | ISL88731 |
| Platform Alias | ZA8 Block Diagram |
ZA8
S1G1
SB600
RS690EWPCE
Azalia 465 FCBGA
775
ALC272
ISL88731
ISL6237
ISL6264A
RT9025
TPS51116
UP6111AQDD
RTS5159B
RTL8103EL
G781
ZA8
S1G1
SB600
RS690EWPCE
Azalia 465 FCBGA
775
ALC272
ISL88731
ISL6237
ISL6264A
RT9025
TPS51116
UP6111AQDD
RTS5159B
RTL8103EL
G781
