acer aspire t5000 usopp sls_quanta zry_rev1a schematic
usopp_sls_ ramp.pdf
usopp_sls_usb rev c_20150114.pdf
This Quanta ZRY02 motherboard, revision 1A, is built around the Intel SkyLake-H processor in a BGA1440 package and the Intel Lynx Point PCH. The platform supports dual-channel DDR4 memory via two SODIMM slots, with a maximum capacity of 16GB per channel. Discrete graphics is handled by an N16P-G GPU, with display output options including eDP, HDMI via an ITE6515 level shifter and PS8407 redriver, and VGA. The embedded controller is an ITE IT8987E/BX, and the audio codec is an ALC255. Networking is provided by an RTL8111GS Gigabit LAN controller. The system also integrates an NPCT650 TPM module and a GL3NB3454 card reader controller.
Q: What is the project code and board number for this motherboard?
A: The project code is ZRY, and the board number is ZRY02.
A: The embedded controller is an ITE IT8987E/BX.
Q: What is the CPU platform and package for this motherboard?
A: The CPU platform is Intel SkyLake-H, and it uses a BGA1440 package.
A: The audio codec is an ALC255.
This Quanta Computer Inc. ZS8 USB board schematic, revision 3B, dated January 14, 2015, documents a dedicated USB board project. The schematic includes a revision history detailing modifications such as the addition of an EMI filter on USB traces, changes to connector pin definitions, and resistor value adjustments from 91 ohm to 90.9 ohm. The board features USB connectors and associated passive components for signal conditioning and power delivery.
Q: What is the board revision and date for this Quanta ZS8 USB board?
A: The schematic is revision 3B, dated Wednesday, January 14, 2015.
Q: What modifications were made to the USB traces in this revision?
A: An EMI filter was added on the USB trace, and resistor values R5692, R6005, R6006, R6007, R6008, R6009 were changed from 91 ohm to 90.9 ohm.
usopp_sls_ ramp.pdf
| Project Code | ZRY |
| Board Number | ZRY02 |
| Revision | 1A |
| Date | Monday, September 07, 2015 |
| CPU Platform | SkyLake-H |
| CPU Model | SKYLAKE_HALO BGA1440 |
| CPU Socket | BGA1440 |
| PCH / Southbridge | Lynx Point |
| EC / KBC | ITE IT8987E/BX |
| Audio Codec | ALC255 |
| LAN IC | RTL8111GS |
| RAM Architecture | L Channel A, L Channel B |
| RAM Quantity / Slots | 2 (SODIMM1, SODIMM2) |
| GPU Type | N16P-G |
| Graphics Architecture | eDP (5.4Gb/s) |
| Card Reader IC | GL3NB3454 |
| TPM IC | NPCT650 |
| HDMI Level Shifter | ITE6515 |
| HDMI Redriver | PS8407 |
| Model | ZS8 |
| Project | USB board |
| Revision | 3B |
| Date | Wednesday, January 14, 2015 |
ZRY02
Skylake-H
Skylake Halo (BGA1440)
IT8987E/BX
ALC255
RTL8111GS
N16P-G
eDP (5.4Gb/s)
GL3NB3454
NPCT650
IT6515
PS8407
ZRY02
Skylake-H
IT8987E/BX
ALC255
RTL8111GS
N16P-G
eDP (5.4Gb/s)
GL3NB3454
NPCT650
IT6515
PS8407
