dell vostro 1000 quanta fx2_rev1a schematic
dell vostro 1000=1=quanta fx2_rev1a.pdf
The Quanta Computer FX21A motherboard, revision 1A, is built around the AMD S1 platform supporting Turion 64 Rev.F Dual-Core and Sempron Rev.F Single-Core processors via a 638 S1g1 socket. The system uses an ATI SB600 southbridge paired with ATI RS485M integrated graphics. Memory is provided by two DDRII SODIMM slots. The embedded controller is an NS97551/87541, and the BIOS is stored on a PC97551 & Flash ROM. Power management is handled by a MAX8731 charger IC and a trio of power ICs: MAX8774 for VHCORE, MAX8734 for system power, and MAX8743 for VCCP and DDR2. Networking is provided by a BCM4401 (B0) LAN controller, and a R5C832 card reader IC is present. The audio subsystem uses an Azalia CODEC.
Q: What is the board number and revision for this Quanta FX21A motherboard?
A: The board number is FX2 MBPCB1, revision 1A.
A: The embedded controller is an NS97551/87541.
Q: What charging IC and power management ICs are used?
A: The charging IC is a MAX8731. The power ICs are MAX8774 (VHCORE), MAX8734 (system), and MAX8743 (VCCP & DDR2).
Q: What CPU socket and platform does this board support?
A: The board uses an AMD S1 platform with a 638 S1g1 socket, supporting Turion 64 Rev.F Dual-Core and Sempron Rev.F Single-Core processors.
| Brand | QUANTA COMPUTER |
| Model | FX21A |
| Project Code | Kirin (FX2 with NS) |
| Board Number | FX2 MBPCB1 |
| Revision | 1A |
| Date | Friday, May 05, 2006 |
| CPU Platform | AMD S1 |
| CPU Model | Turion 64 Rev.F Dual-Core / Sempron Rev.F Single-Core |
| CPU Socket | 638 S1g1 socket |
| PCH / Southbridge | ATI SB600 |
| GPU Type | ATI RS485M |
| Graphics Architecture | RS485 A12 |
| EC / KBC | NS97551 / 87541 |
| Audio Codec | Azalia CODEC |
| BIOS / SPI Flash | PC97551 & FLASH |
| Charging IC | MAX8731 |
| Charger Architecture | CHARGER (MAX8731) |
| Power IC(s) | MAX8774, MAX8734, MAX8743 |
| RAM Type | DDRII |
| RAM Architecture | DDRII-SODIMM1, DDRII-SODIMM2 |
| Card Reader IC | R5C832 |
| LAN IC | BCM4401 (B0) |
| WiFi / WLAN IC | Mini Card (WLAN) |
FX2
FX2 MBPCB1
S1
638 S1G1
SB600
RS485M
RS485 A12
NS97551 / 87541
PC97551
MAX8731
MAX8734
MAX8743
MAX8774
R5C832
BCM4401
FX2
FX2 MBPCB1
S1
638 S1G1
SB600
RS485M
RS485 A12
NS97551 / 87541
PC97551
MAX8731
MAX8734
MAX8743
MAX8774
R5C832
BCM4401
