dell v3450_n4110 v02a_r01a_dis_rev1a_quanta v02a schematic
dell v3450_n4110=1=v02a_r01a_dis_rev1a_quanta v02a.pdf
This Quanta Computer Inc. block diagram, revision V02A/R01A dated January 19, 2011, details a motherboard platform built around an Intel Sandy Bridge 35W CPU and a Couger Point HM67 PCH. The graphics subsystem supports multiple configurations including a Whistler LP (128bit) 29mm X 29mm BGA 969, Seymour XT (64bit), and Robson XT (64bit) dGPUs. Memory architecture consists of two DDRIII-SODIMM slots supporting DDRIII 1333 MT/s. The platform integrates a Realtek LAN controller and an ALC 269 audio codec. The block diagram also indicates the presence of a charger, SPI ROM, and various power rails including VCCSA, CPU_CORE, and DGFX_CORE.
Q: What is the CPU platform and PCH used on this motherboard?
A: The CPU platform is Sandy Bridge 35W and the PCH is Couger Point HM67.
Q: What dGPU options are supported on this platform?
A: The block diagram lists Whistler LP (128bit) 29mm X 29mm BGA 969, Seymour XT (64bit), and Robson XT (64bit) as dGPU options.
Q: What type of memory and how many slots are used?
A: The platform uses DDRIII memory with two DDRIII-SODIMM slots supporting DDRIII 1333 MT/s.
Q: What audio codec and LAN controller are integrated?
A: The audio codec is ALC 269 and the LAN controller is Realtek.
| Project | BLOCK DIAGRAM |
| Revision | V02A/R01A |
| Date | Wednesday, January 19, 2011 |
| CPU Platform | Sandy Bridge 35W |
| PCH / Southbridge | Couger Point HM67 |
| GPU Type | Whistler LP (128bit) 29mm X 29mm BGA 969 / Seymour XT (64bit) / Robson XT (64bit) |
| Graphics Architecture | DGFX_CORE |
| RAM Architecture | DDRIII-SODIMM1 / DDRIII-SODIMM2 |
| LAN IC | REALTEK LAN |
| Audio Codec | ALC 269 |
