dell quanta v02a dis mb a01 20110119 1
This Quanta Computer Inc. motherboard, revision 1A dated January 19, 2011, is built around an Intel Sandy Bridge 35W CPU platform in a PGA 988 socket, paired with a Mobile Intel Series 6 Chipset Couger Point PCH in a BGA 989 package. The discrete graphics subsystem features a Whistler LP (128-bit) GPU in a 29mm x 29mm BGA 969 package, with an additional Seymour XT (64-bit) dGPU supported by 2GB of DDR3 memory configured as 128Mx16bitx8. System memory consists of two DDRIII-SODIMM slots supporting 1333 MT/s. The embedded controller is an ITE 8518, and the BIOS is stored on a 4MB SPI ROM. Audio is handled by a Realtek ALC 269 codec, while networking includes a Realtek RTL8111EL LAN controller and a WLAN module. A Realtek RTL5128-GR card reader IC is present, along with an HDMI level shifter and a 3-axis fall sensor.
A: The embedded controller is an ITE 8518.
A: The BIOS is stored on a 4MB SPI ROM.
Q: What discrete GPU configurations are present on this motherboard?
A: The motherboard includes a Whistler LP (128-bit) GPU in a 29mm x 29mm BGA 969 package and a Seymour XT (64-bit) dGPU with 2GB of DDR3 memory (128Mx16bitx8).
A: The motherboard uses two DDRIII-SODIMM slots supporting 1333 MT/s.
| Project Code | V02A/R01A DIS BLOCK DIAGRAM |
| Revision | 1A |
| Date | Wednesday, January 19, 2011 |
| CPU Platform | Sandy Bridge 35W |
| CPU Socket | PGA 988 |
| PCH / Southbridge | Couger Point |
| PCH / Southbridge Package | BGA 989 |
| GPU Type | Whistler LP ([URL="https://dr-bios.com/components/graphics-models/128bit/"]128bit)[/URL] |
| GPU Package | 29mm X 29mm BGA 969 |
| dGPU Chip Number | Seymour XT (64bit) |
| dGPU Memory | DDR3 2GB 128Mx16bitx8 |
| EC / KBC | ITE 8518 |
| Audio Codec | ALC 269 |
| BIOS Flash Capacity | 4MB |
| Charging IC | Charger |
| RAM Architecture | DDRIII-SODIMM1, DDRIII-SODIMM2 |
| RAM Speed | 1333 MT/s |
| Card Reader IC | RTL5128-GR |
| LAN IC | RTL8111EL |
| WiFi / WLAN IC | WLAN |
| HDMI Level Shifter | LEVEL SHIFTER |
| Thermal Sensor | 3-axis Fall Sensor |
| PCH / Southbridge Chipset | Mobile Intel Series 6 Chipset |
