dell studio 1555 1557 1558 quanta fm9b-c2b uma 090904 1
The Quanta Computer FM9B2B is a motherboard revision 2B based on the FM9 HANKS platform, dated August 20, 2009. It supports the Clarksfield/Auburndale CPU platform via an rPGA 989 socket and utilizes the Intel HM55 PCH. The system memory architecture is dual-channel DDR3 with two SO-DIMM slots. The embedded controller is an ITE8502, which has a dedicated 1Mbyte flash. The main BIOS SPI flash is 4Mbytes. Audio is handled by a 92HD73C codec. The charging circuit uses a MAX8731 charger IC. Power regulation is managed by multiple ICs including TPS51427A, MAX17028, TPS51116, TPS51218, RT9018, RT9024, and MAX17036. The LAN controller is an RTL8111DL, and the wireless module includes a BT365. The HDMI level shifter is a PI3VDP411LSZ, and the clock generator is an SLG8SP585VTR. The card reader controller is an R5U230, and a USB hub IC, SN75LVCP412, is also present.
A: The main BIOS SPI flash is 4Mbytes.
Q: What EC/KBC is used and does it have a dedicated flash?
A: The EC/KBC is an ITE8502, and it has a dedicated 1Mbyte flash.
Q: What is the memory architecture and type?
A: The memory architecture is dual-channel DDR3 with two SO-DIMM slots.
| Brand | QUANTA COMPUTER |
| Model | FM9B2B |
| Board Number | FM9B HANKS |
| Revision | 2B |
| Date | Thursday, August 20, 2009 |
| CPU Platform | Clarksfield/Auburndale |
| CPU Socket | rPGA 989 |
| PCH / Southbridge | HM55 |
| EC / KBC | ITE8502 |
| Audio Codec | 92HD73C |
| BIOS / SPI Flash | SPI |
| BIOS Flash Capacity | 4Mbytes |
| EC Flash / ROM | 1Mbytes |
| Charging IC | MAX8731 |
| Power IC(s) | TPS51427A, MAX17028, TPS51116, TPS51218, RT9018, RT9024, MAX17036 |
| Card Reader IC | R5U230 |
| LAN IC | RTL8111DL |
| WiFi / WLAN IC | BT365 |
| HDMI Level Shifter | PI3VDP411LSZ |
| Clock Generator | SLG8SP585VTR |
| USB Hub IC | SN75LVCP412 |
FM9B HANKS
Auburndale
Clarksfield
989
HM55
IT8502
92HD73C
1MBYTES
MAX8731
MAX17028
MAX17036
RT9018
RT9024
TPS51116
TPS51218
TPS51427A
R5U230
RTL8111DL
BT365
PI3VDP411LSZ
SLG8SP585VTR
SN75LVCP412
FM9B HANKS
Auburndale
Clarksfield
989
HM55
IT8502
92HD73C
1MBYTES
MAX8731
MAX17028
MAX17036
RT9018
RT9024
TPS51116
TPS51218
TPS51427A
R5U230
RTL8111DL
BT365
PI3VDP411LSZ
SLG8SP585VTR
SN75LVCP412
