dell studio 1555 1557 1558 quanta fm9-d3b dis 090814 1
The Quanta Computer FM93B motherboard, revision 3B, is built around the Arrandale/Clarksfield CPU platform with an Intel Discrete GFX architecture featuring an ATI M92-XT GPU. The system employs an ITE8502 EC/KBC and utilizes dual SPI flash devices: FLASH1 at 1Mbyte and FLASH2 at 2Mbytes. Memory configuration consists of two DDR3 SO-DIMM slots supporting dual channel DDR3 800/1066/1333 at 1.5V. Power management is handled by a MAX8731 charger, with multiple power ICs including TPS51427A, MAX8792, TPS51116, TPS51218, MAX17036, RT9018, and RT9024. The audio subsystem uses a 92HD73C codec, networking is provided by an RTL8111DL LAN IC, and the clock generator is an LG8SP585VTR in a QFN-32 package. Thermal monitoring is managed by an SMSC1422 sensor, and the system includes an R5U230 card reader and USB hub IC.
A: The motherboard uses two SPI flash devices: FLASH1 at 1Mbyte and FLASH2 at 2Mbytes.
A: The motherboard uses an ITE8502 EC/KBC.
A: The charging IC is a MAX8731.
Q: What is the memory configuration on this motherboard?
A: The motherboard supports dual channel DDR3 800/1066/1333 at 1.5V across two SO-DIMM slots.
| Brand | QUANTA COMPUTER |
| Model | FM93B |
| Board Number | FM9 HANKS |
| Revision | 3B |
| Date | Monday, August 10, 2009 |
| CPU Platform | Arrandale/ Clarksfield |
| GPU Type | ATI M92-XT |
| Graphics Architecture | Intel Discrete GFX |
| EC / KBC | ITE8502 |
| Audio Codec | 92HD73C |
| BIOS / SPI Flash | FLASH1, FLASH2 |
| BIOS Flash Capacity | 1Mbytes, 2Mbytes |
| Charging IC | MAX8731 |
| Power IC(s) | TPS51427A, MAX8792, TPS51116, TPS51218, MAX17036, RT9018, RT9024 |
| RAM Architecture | Dual Channel DDR3 800/1066/1333 1.5V |
| Card Reader IC | R5U230 |
| LAN IC | RTL8111DL |
| WiFi / WLAN IC | MINI-CARD WLAN |
| HDMI Level Shifter | SN75LVCP412 |
| Clock Generator | LG8SP585VTR (QFN-32) |
| Thermal Sensor | SMSC1422 |
| USB Hub IC | R5U230 |
FM9 HANKS
Arrandale
Clarksfield
M92 XT
Intel Discrete GFX
IT8502
92HD73C
FLASH1, FLASH2
MAX8731
MAX17036
MAX8792
RT9018
RT9024
TPS51116
TPS51218
TPS51427A
R5U230
RTL8111DL
SN75LVCP412
LG8SP585VTR
SMSC1422
R5U230
FM9 HANKS
Arrandale
Clarksfield
M92 XT
Intel Discrete GFX
IT8502
92HD73C
FLASH1, FLASH2
MAX8731
MAX17036
MAX8792
RT9018
RT9024
TPS51116
TPS51218
TPS51427A
R5U230
RTL8111DL
SN75LVCP412
LG8SP585VTR
SMSC1422
R5U230
