dell n5110 10260-1.48.4ie07.011dq15 dis-uma 1
This Wistron QUEEN 15A00 motherboard, documented under A31108 Rev A00 dated January 4, 2011, is built around the Intel Sandy Bridge CPU platform paired with the Cougar Point PCH. The board supports a Discrete/UMA co-lay graphics architecture, with the N12P-GE-A1-GP as the discrete GPU option. HDMI routing is configurable via 0-ohm resistors, allowing selection between UMA or dGPU sources for both ATI and NVidia implementations. System management is handled by the NPCE795P EC/KBC, which includes a PSL circuit for 10mW low-power operation. The BIOS is stored on a 4MB SPI flash ROM. Power management is distributed across multiple ICs including the BQ24745 charger, RT8208B, ISL95831HRTZ, TPS51216RUKR, TPS51123RGER, TPS51218, TPS513113, and APL5916. Audio is provided by the IDT92HD87D codec, networking by the RTL8111E/8105E, and card reading by the RTS5138. The board features two DDRIII 1066/1333 memory slots and a NEC UPD720200FA USB 3.0 controller. The PCB is identified as 10260-1 with project code 91.4IE01.001.
A: The NPCE795P EC/KBC is used, with a PSL circuit for 10mW low-power solution installed
| Project Code | QUEEN 15A00 |
| Document Number | A31108 |
| Revision | A00 |
| Date | Tuesday, January 04, 2011 |
| CPU Platform | Sandy Bridge |
| PCH / Southbridge | Cougar Point |
| GPU Type | Discrete/UMA co-lay |
| dGPU Chip Number | N12P-GE-A1-GP |
| dGPU to UMA Conversion Support | ATI: Co-layout HDMI coming from UMA(default) & dGPU by reserving Resistor(0ohm) for optional selection. NVidia: Co-layout HDMI coming from dGPU(Default) & UMA by reserving Resistor(0ohm) for optional selection. |
| EC / KBC | NPCE795P |
| EC/KBC Programmable | PSL: KBC795 PSL circuit for 10mW solution installed |
| Audio Codec | IDT92HD87D |
| BIOS / SPI Flash | SPI Flash ROM 4MB |
| Charging IC | BQ24745 |
| Power IC(s) | RT8208B, ISL95831HRTZ, TPS51216RUKR, TPS51123RGER, TPS51218, TPS513113, APL5916 |
| RAM Type | DDRIII 1066/1333 |
| Card Reader IC | RTS5138 |
| USB Hub IC | UPD720200FA |
| LAN IC | RTL8111E/8105E |
| WiFi / WLAN IC | 802.11a/b/g |
| HDMI Level Shifter | ATI: Co-layout HDMI coming from UMA(default) & dGPU by reserving Resistor(0ohm) for optional selection. NVidia: Co-layout HDMI coming from dGPU(Default) & UMA by reserving Resistor(0ohm) for optional selection. |
| PCB Number | 10260-1 |
| Project Code (Alternate) | 91.4IE01.001 |
15A00
Sandy Bridge
co-lay
N12P-GE-A1-GP
NPCE795P
IDT92HD87D
BQ24745
APL5916
ISL95831HRTZ
RT8208B
TPS51123RGER
TPS51216RUKR
TPS51218
TPS513113
RTS5138
UPD720200FA
RTL8111E / 8105E
10260-1
15A00
Sandy Bridge
co-lay
N12P-GE-A1-GP
NPCE795P
IDT92HD87D
BQ24745
APL5916
ISL95831HRTZ
RT8208B
TPS51123RGER
TPS51216RUKR
TPS51218
TPS513113
RTS5138
UPD720200FA
RTL8111E / 8105E
10260-1
