Schematic dell inspiron n4020 dj1-monteviana-uma-09275-1 intel gm45 schematic
dell inspiron n4020 dj1-monteviana-uma-09275-1 intel gm45 1
BrandWistron Corporation
ModelDJ1 INTEL IO Board
Motherboard ManufacturerWistron Corporation
Project Code91.4EK01.001
Board NumberDJ1 IO Board
RevisionA00
DateTuesday, February 23, 2010
CPU PlatformIntel GM45+ICH9M
Document NumberA31
PCB Number09783-1
PCB P/N48.4EK13.0SB
This Wistron DJ1 INTEL IO Board, revision A00, is based on the Intel GM45+ICH9M platform supporting a uFCPGA Mobile Penryn processor. The board is identified by project code 91.4EK01.001 and PCB number 09783-1, with PCB part number 48.4EK13.0SB. The schematic document number is A31, dated February 23, 2010. The board includes a DC-in connector (DCIN1, SKT-JACK-204-GP-U, 22.10037.D61) and a main IO board connector (IOBD2, ACES-CONN60E-1-GP). Power input is managed through a P-channel MOSFET (PU201, AO4407-GP) and a TVS diode (PD201, 1SMB22AT3G-GP-U). The design includes multiple depopulation options for components such as EC203, EC209, EC213, and others, as well as "Do Not Stuff" positions for several resistors and capacitors.
Q: What is the platform architecture of this Wistron DJ1 IO Board?
A: The board uses the Intel GM45+ICH9M chipset platform, supporting a uFCPGA Mobile Penryn processor.
Q: What are the key board identification numbers for this schematic?
A: The project code is 91.4EK01.001, the PCB number is 09783-1, the PCB part number is 48.4EK13.0SB, and the document number is A31.
Q: What is the revision and date of this schematic?
A: The schematic is revision A00, dated Tuesday, February 23, 2010.
ModelDJ1 Montevina UMA
Board Number48.4EK06.0SA
Revision09275-SA
Date2010-02-10
CPU SocketSocket P
CPU Model[URL="https://dr-bios.com/components/cpu-model/intel-mobile-cpu/"]Intel Mobile CPU Penryn[/URL]
PCH / SouthbridgeICH9-M
GPU TypeIntegrated (UMA)
Graphics ArchitectureGM45
EC / KBCNPCE781BA0DX
EC/KBC PackageNUVOTON
Audio CodecIDT92HD79B1
BIOS / SPI Flash2MB Flash ROM
Charging ICBQ24745
Charger ArchitectureMAXIM CHARGER
Power IC(s)TPS51620, TPS51116, TPS51125, TPS51218, TPS51620
RAM TypeDDRIII 800/1066
RAM ArchitectureDual Channel
RAM Quantity / Slots2
Card Reader ICRealtek RTS5138
LAN ICAR8132
WiFi / WLAN IC802.11a/b/g Mini-Card
Thermal SensorEMC2102
The Wistron DJ1 Montevina UMA motherboard, project code 91.4EK01.001 and board number 48.4EK06.0SA revision 09275-SA, is built around the Intel GM45+ICH9M platform supporting a Socket P Intel Mobile Penryn CPU. Graphics are integrated via the GM45 UMA architecture. The system utilizes dual-channel DDRIII 800/1066 memory across two slots. The embedded controller is a Nuvoton NPCE781BA0DX, and the audio codec is an IDT92HD79B1. Power management is handled by a BQ24745 charger and multiple DC/DC converters including TPS51620, TPS51116, TPS51125, and TPS51218. The BIOS is stored on a 2MB Flash ROM. Networking is provided by an AR8132 LAN IC and an 802.11a/b/g Mini-Card WLAN. A Realtek RTS5138 card reader and an EMC2102 thermal sensor are also present.
A: The board number is 48.4EK06.0SA, and the project code is 91.4EK01.001.
A: The embedded controller is a Nuvoton NPCE781BA0DX.
A: The BIOS is stored on a 2MB Flash ROM.
Q: What charging IC and architecture are used?
A: The charging IC is a BQ24745, part of the MAXIM CHARGER architecture.
Revision09275-SA / A00
DateWednesday, February 24, 2010
CPU Model[URL="https://dr-bios.com/components/cpu-model/intel-mobile-cpu/"]Intel Mobile CPU Socket P[/URL]
CPU SocketSocket P
Charging ICBQ24745
LAN ICAR8132
The Wistron DJ1 Montevina UMA motherboard, project code 91.4EK01.001 with board number 48.4EK06.0SA revision 09275-SA/A00, is built on the Intel GM45+ICH9M platform supporting an Intel Mobile CPU in Socket P. Graphics are integrated via the GM45 UMA architecture. The system uses dual-channel DDRIII 800/1066 memory across two slots. The embedded controller is an NPCE781BA0DX from NUVOTON. Audio is handled by an IDT92HD79B1 codec. The BIOS is stored on a 2MB Flash ROM. Power management includes a BQ24745 charger and multiple TPS-series DC/DC converters. Networking is provided by an AR8132 10/100 NIC and an 802.11a/b/g Mini-Card. A Realtek RTS5138 card reader supports SD/MMC/MS/MS Pro/xD formats.
A: The embedded controller is an NPCE781BA0DX from NUVOTON.
A: The BIOS is stored on a 2MB Flash ROM connected via the LPC bus.
A: The motherboard supports dual-channel DDRIII 800/1066 memory across two SO-DIMM slots.
A: The charger IC is a BQ24745 from Texas Instruments.
RevisionA00
CPU ModelIntel Mobile CPU
CPU SocketSocket P
GPU TypeIntegrated
Charging ICBQ24745
Power IC(s)TPS51125, TPS51218, TPS51116, TPS51620
LAN ICAR8132
The Wistron DJ1 Montevina UMA (Project Code 91.4EK01.001, Board Number 48.4EK06.0SA, Revision A00) is a laptop motherboard designed around the Intel GM45+ICH9M chipset platform, supporting Socket P Intel Mobile CPUs. Graphics are integrated via the GM45 architecture. The system utilizes two DDRIII 800/1066 memory slots in a dual-channel configuration. Power management is handled by a BQ24745 charger IC and multiple DC/DC converters including TPS51125, TPS51218, TPS51116, and TPS51620. The embedded controller is a Nuvoton NPCE781BA0DX. Audio is provided by an IDT92HD79B1 codec. The BIOS is stored on a 2MB Flash ROM. Networking includes an Atheros AR8132 10/100 NIC and an 802.11a/b/g Mini-Card WLAN. A Realtek RTS5138 card reader supports SD/MMC/MS/MS Pro/xD formats.
Q: What charging IC and power management ICs are used?
A: The charging IC is a BQ24745. Power management ICs include TPS51125, TPS51218, TPS51116, and TPS51620.
Q: What memory type and configuration does this board support?
A: The board supports DDRIII 800/1066 memory in a dual-channel configuration across two slots.
DateThursday, December 10, 2009
CPU PlatformICH9M
PCH / SouthbridgeICH9M
This Wistron Corporation motherboard schematic, dated December 10, 2009, is built around the ICH9M platform. The document details the DJ MV UMA power-up sequence, specifying critical timing and voltage ramp requirements for the ICH9M southbridge. Key power rails include +3.3V_ALW, +5V_ALW, +3.3V_RUN, +5V_RUN, +1.5V_RUN, +1.05V_VCCP, and VCC_CORE. The schematic enforces strict sequencing rules, such as +5V_ALW ramping before +3.3V_ALW, and +5V_RUN ramping before +3.3V_RUN, with a maximum voltage difference of 0.7V. Timing constraints require VRMPWRGD to precede PM_PWROK by at least 3ms, and PM_PWROK to precede PLTRST# by 1ms to 2.2ms. The power sequence is initiated by KBC_PWRBTN# and PM_PWRBTN# signals, with AC adapter insertion and pre-boot CPU VID value configuration.
Q: What is the platform architecture of this motherboard?
A: The motherboard is based on the ICH9M platform.
Q: What are the critical power sequencing rules for this motherboard?
A: The schematic specifies that +5V_ALW must ramp before +3.3V_ALW, and +5V_RUN must ramp before +3.3V_RUN, with a maximum voltage difference of 0.7V. Additionally, +1.5V_RUN must ramp before +1.05V_VCCP.
Q: What are the timing constraints for PM_PWROK and PLTRST#?
A: VRMPWRGD must come up at least 3ms before PM_PWROK, and PM_PWROK must come up between 1ms and 2.2ms before PLTRST#.
  • Dell_Inspiron_N4020=1=DJ1-Monteviana-UMA-09275-1_Intel_GM45.zip
