dell inspiron 1100 compal_la-1452_rev1c schematic
dell inspiron 1100=1=compal_la-1452_rev1c.pdf
This Dell-Compal Abacus/TangII motherboard, Compal board number LA-1452 revision 1C, is built around the uFCBGA/uFCPGA Northwood CPU platform with an Intel ICH4 southbridge. Graphics are handled by either an Intel 845PE or 845GL GPU via an AGP 4X interface. The embedded controller is an NS EC87591L in a 100 BGA package. Audio is provided by a STAC9750 AC97 codec, and system management is supported by an ADM1032 thermal sensor. Power management is handled by a MAX1632 charging IC alongside ISL6215, ISL6225, ISL6219, and CM2843 power ICs. The board supports two DDR-DIMM slots for memory expansion. Connectivity includes a BCM-4401L LAN IC, a Mini PCI connector for wireless, and a PCI4510 or PCI1510 card reader controller. The clock generator is an ICS950810.
Q: What is the board number and revision for this motherboard?
A: The board number is LA-1452, revision 1C.
Q: What embedded controller is used on this motherboard?
A: The embedded controller is an NS EC87591L in a 100 BGA package.
A: The audio codec is a STAC9750.
A: The charging IC is a MAX1632.
| Brand | Dell-Compal |
| Model | Abacus/TangII |
| Board Number | LA-1452 |
| Revision | 1C |
| Date | 2003-02-24 |
| CPU Platform | uFCBGA/uFCPGA Northwood |
| PCH / Southbridge | ICH4 |
| GPU Type | 845PE / 845GL |
| Graphics Architecture | AGP 4X (1.5V) |
| EC / KBC | NS EC87591L |
| EC/KBC Package | 100 BGA |
| Audio Codec | STAC9750 |
| BIOS / SPI Flash | BIOS |
| Charging IC | MAX1632 |
| Power IC(s) | ISL6215, ISL6225, ISL6219, CM2843 |
| RAM Architecture | DDR-DIMM X2 |
| Thermal Sensor | ADM1032 |
| Card Reader IC | PCI4510 / PCI1510 |
| LAN IC | BCM-4401L |
| WiFi / WLAN IC | Mini PCI CONN |
| Clock Generator | ICS950810 |
LA-1452
Northwood
ICH4
845GL
845PE
AGP 4X (1.5V)
NS EC87591L
STAC9750
MAX1632
CM2843
ISL6215
ISL6219
ISL6225
DDR
ADM1032
PCI1510
PCI4510
BCM-4401L
ICS950810
LA-1452
Northwood
ICH4
845GL
845PE
AGP 4X (1.5V)
NS EC87591L
STAC9750
MAX1632
CM2843
ISL6215
ISL6219
ISL6225
DDR
ADM1032
PCI1510
PCI4510
BCM-4401L
ICS950810
