benq joybook lite u105i ntv00_la-5662p_rev1.0 schematic
benq joybook lite u105i=1=ntv00_la-5662p_rev1.0.pdf
The Compal A5662 motherboard, documented under board number LA-5662 revision 0.2, is built around the Intel PineView-M processor paired with the Tiger Point PCH. The platform integrates graphics within the PineView-M CPU and supports a single 204-pin DDRIII SO-DIMM memory module. System management is handled by an ENE KB926 D3 embedded controller, while audio is provided by a Realtek ALC272-GR codec. The BIOS is stored on a SPI ROM. Networking is supported by a Realtek RTL8103EL 10/100M LAN controller, and a Realtek RTS5159 2IN1 card reader is included for media card support. Thermal monitoring is managed by an EMC1402 sensor. The schematic, dated June 4, 2010, was authored by Compal Electronics, Inc.
A: The embedded controller is an ENE KB926 D3.
A: The audio codec is a Realtek ALC272-GR.
A: The LAN controller is a Realtek RTL8103EL 10/100M.
Q: What card reader controller is used on this motherboard?
A: The card reader controller is a Realtek RTS5159 2IN1.
Q: What thermal sensor is used on this motherboard?
A: The thermal sensor is an EMC1402.
| Model | A5662 |
| Board Number | LA-5662 |
| Revision | 0.2 |
| Date | Friday, June 04, 2010 |
| Document Number | 401898B |
| CPU Platform | Intel PineView-M |
| PCH / Southbridge | Tiger Point |
| EC / KBC | ENE KB926 D3 |
| Audio Codec | ALC272-GR |
| LAN IC | RTL8103EL 10/100M |
| Card Reader IC | RTS5159 2IN1 |
| RAM Architecture | 204pin DDRIII-SO-DIMM |
| RAM Quantity / Slots | 1 |
| Thermal Sensor | EMC1402 |
| WiFi / WLAN IC | PCIeMini Card WLAN |
| Audio Amplifier | TPA6017 |
| Clock Generator | SLG8SP556VTR |
| GPU Type | Intel Pineview-M |
| Graphics Architecture | Integrated |
