BenQ Joybook Lite U105i NTV00 LA-5662P Rev 1.0 Schematic
This Compal LA-5662 Rev 0.2 schematic, dated June 4, 2010, details a motherboard built around the Intel PineView-M processor paired with the Tiger Point PCH. The platform supports a single 204-pin DDRIII SO-DIMM module for memory. System management is handled by an ENE KB926 D3 embedded controller. Audio is provided by a Realtek ALC272-GR codec, while networking is managed by a Realtek RTL8103EL 10/100M Ethernet controller. Storage and media are supported by a Realtek RTS5159 2-in-1 card reader. The system clock is generated by an SLG8SP556VTR clock generator, and thermal monitoring is performed by an EMC1402 sensor. Audio output is amplified by a TPA6017 amplifier. The BIOS is stored on a SPI ROM.
A: The embedded controller is an ENE KB926 D3.
A: The audio codec is a Realtek ALC272-GR.
A: The LAN IC is a Realtek RTL8103EL 10/100M.
Q: What card reader IC is used on this motherboard?
A: The card reader IC is a Realtek RTS5159 2IN1.
| Board Number | LA-5662 |
| Revision | 0.2 |
| Date | Friday, June 04, 2010 |
| CPU Platform | Intel PineView-M |
| PCH / Southbridge | Tiger Point |
| EC / KBC | ENE KB926 D3 |
| Audio Codec | ALC272-GR |
| RAM Architecture | 204pin DDRIII-SO-DIMM |
| LAN IC | RTL8103EL 10/100M |
| Card Reader IC | RTS5159 2IN1 |
| Audio Amplifier | TPA6017 |
| Clock Generator | SLG8SP556VTR |
| Thermal Sensor | EMC1402 |
