Schematic Acer TravelMate 8372 8372T 8372TZ 6050a2341701 Schematic
BrandInventec
ModelBAP/BXP30
Motherboard ManufacturerInventec
Project CodeCS-131X01
Board NumberCS-131X01
RevisionX01
DateSaturday, May 22, 2010
CPU PlatformArrandale
CPU SocketRPGA,989
PCH / SouthbridgeIbexpeak-M
GPU TypeN10x
Graphics ArchitectureN10x With DDR3 Maximum 512MB
EC / KBCITE8502E
EC/KBC Package80
Audio CodecCX20671
BIOS / SPI FlashFlash ROM
Charging ICISL6251
Charger ArchitectureBattery 109V~12.6V
Power IC(s)TPS51621, TPS51611, TPS51218, TPS51125, TPC6111, G2997, TPS51117, FDS8884, SI2301, SI2301, FDMC4435BZ, SC471, SC471
RAM TypeDDR3
RAM ArchitectureDDR3 1.5V 800/1066/1333MHz
RAM Quantity / Slots2
Card Reader IC5 In 1 Card Reader
LAN ICBCM57760
WiFi / WLAN ICMini Card (WLAN)
This Inventec BAP/BXP30 motherboard, project code CS-131X01 revision X01, is built around an Arrandale CPU platform using an RPGA,989 socket paired with an Ibexpeak-M PCH. The graphics subsystem is an N10x GPU with up to 512MB of dedicated DDR3 VRAM. System memory consists of two DDR3 SO-DIMM slots supporting 1.5V 800/1066/1333MHz modules. The embedded controller is an ITE8502E in an 80-pin package, while the audio codec is a CX20671. Wired networking is handled by a BCM57760 LAN IC. The charging architecture uses an ISL6251 controller supporting a battery voltage range of 109V to 12.6V. Multiple power ICs including TPS51621, TPS51611, TPS51218, TPS51125, TPC6111, G2997, TPS51117, FDS8884, SI2301, SI2301, FDMC4435BZ, and SC471 manage the various voltage rails. The board includes a 5-in-1 card reader and supports Mini Card WLAN modules.
A: The embedded controller is an ITE8502E in an 80-pin package.
Q: What is the charging IC and battery voltage range?
A: The charging IC is an ISL6251, supporting a battery voltage range of 109V to 12.6V.
Q: What audio codec is used on this board?
A: The audio codec is a CX20671.
Q: What LAN IC is used?
A: The LAN IC is a BCM57760.
  • Acer TravelMate 8372 8372T 8372TZ 6050a2341701 Schematic.pdf
