acer travelmate 4240 4420 4520 wistron orta rev-sa 1
The Wistron Orta motherboard, project code 91.4U101.001 with board number 48.4U101.0SA revision 06245-SA, is an AMD-based platform designed around the K8 Rev. GS1g1 Socket PA CPU architecture. The platform integrates an ATI RS690M graphics solution paired with an SB600 southbridge. System memory is provided by two DDR2 SODIMM slots supporting DDR II 533/667/800 modules. The embedded controller is a Winbond WPC8768L, while the BIOS SPI flash is a Winbond W25X80-V. Audio is handled by an ALC268 codec, and networking is provided by a BCM5787M LAN controller. The charging circuit utilizes an O2OZ711 IC. Additional connectivity includes a G1432Q card reader, a CP2211F USB hub, and a G1410Q wireless module.
A: The BIOS SPI flash is a Winbond W25X80-V.
A: The embedded controller is a Winbond WPC8768L.
A: The charging IC is an O2OZ711.
Q: What is the LAN IC on this motherboard?
A: The LAN IC is a BCM5787M.
| Brand | Wistron |
| Model | Orta |
| Project Code | 91.4U101.001 |
| Board Number | 48.4U101.0SA |
| Revision | 06245-SA |
| Date | Tuesday, December 12, 2006 |
| Document Number | SA |
| CPU Platform | AMD K8 Rev. GS1g1 Socket PA |
| PCH / Southbridge | SB600 |
| GPU Type | [URL="https://dr-bios.com/components/graphics-models/ati/"]ATI RS690M[/URL] |
| Graphics Architecture | ATI |
| EC / KBC | WPC8768L |
| EC/KBC Manufacturer | Winbond |
| Audio Codec | ALC268 |
| BIOS / SPI Flash | W25X80-V |
| BIOS Flash Manufacturer | Winbond |
| BIOS Flash Capacity | 1MB (8Mbit) |
| Charging IC | O2OZ711 |
| RAM Type | DDR2 SODIMM |
| RAM Architecture | DDR II 533/667/800 |
| LAN IC | BCM5787M |
| Card Reader IC | G1432Q |
| USB Hub IC | CP2211F |
| WiFi / WLAN IC | G1410Q |
91.4U101.001
48.4U101.0SA
K8 REV GS1G1 PA
SB600
RS690M
ATI
WPC8768L
ALC268
W25X80-V
O2OZ711
BCM5787M
G1432Q
CP2211F
G1410Q
91.4U101.001
48.4U101.0SA
K8 REV GS1G1 PA
SB600
RS690M
ATI
WPC8768L
ALC268
W25X80-V
O2OZ711
BCM5787M
G1432Q
CP2211F
G1410Q
