acer aspire 4520 series quanta zo3 da0zo3mb6e0_rev1a schematic
acer aspire 4520 series=1=quanta zo3 da0zo3mb6e0_rev1a.pdf
The Quanta ZO3 motherboard is an AMD S1g1 platform designed for Turion 64 Dual-Core or Sempron Single-Core processors in an FCPGA638 socket. The system is built around the n-Vidia MCP67 chipset, which integrates both the southbridge and GPU functions. Memory architecture consists of dual-channel DDR2, supported by two SO-DIMM slots. The embedded controller is a Winbond WPC8769LDG, and the audio subsystem is handled by a RealTek ALC268 codec. System BIOS is stored on a SPI ROM. Power management is managed by an ISL6262A Vcore regulator, a TPS51120 for 5V/3.3V generation, and a MAX 1993 for VGA-core power, with battery charging controlled by an ISL6251. Networking is provided by a Realtek RTL8211B PHY, and a Ricoh R5C833 controller manages media card reader and IEEE 1394 functions.
A: The embedded controller is a Winbond WPC8769LDG.
A: The battery charger IC is an ISL6251.
A: The audio codec is a RealTek ALC268.
Q: What is the LAN PHY on this motherboard?
A: The LAN PHY is a Realtek RTL8211B.
| Brand | Quanta |
| Model | ZO3 |
| Project Code | ZO3 |
| Date | Wednesday, April 25, 2007 |
| CPU Platform | AMD S1g1 |
| CPU Model | Turion 64 Dual-Core / Sempron Single-Core |
| CPU Socket | FCPGA638 |
| PCH / Southbridge | n-Vidia MCP67 |
| GPU Type | n-Vidia MCP67 |
| EC / KBC | WPC8769LDG |
| Audio Codec | RealTek ALC268 |
| Charging IC | ISL6251 |
| Power IC(s) | ISL6262A, TPS51120, MAX 1993 |
| RAM Type | DDR2 |
| RAM Architecture | Dual Channel DDR2 |
| RAM Quantity / Slots | SO-DIMM 0, SO-DIMM 1 |
| Card Reader IC | Ricoh R5C833 |
| LAN IC | Realtek RTL8211B |
| WiFi / WLAN IC | Mini Card / WLAN |
ZO3
S1G1
N-VIDIA MCP67
n-Vidia MCP67
WPC8769LDG
ALC268
ISL6251
ISL6262A
MAX1993
TPS51120
RICOH R5C833
RTL8211B
ZO3
S1G1
N-VIDIA MCP67
n-Vidia MCP67
WPC8769LDG
ALC268
ISL6251
ISL6262A
MAX1993
TPS51120
RICOH R5C833
RTL8211B
